So I need to order parts online. We had a great electronic supply store here in Berkeley for 60 years (Al Lashers interview) but they closed recently. There's a few places south in the San Francisco Bay Area but I haven't had the time to check them out.
Since I'm placing an order, are there any other components I should pick up while I'm at it? Ill be getting a 1k ohm ceramic resistor to drain the big capacitors and a 1N4148 diode. I have read on other posts that the blue Sayno capacitators are notoriously prone to failure, any sense in replacing these on the board while its out?
I noticed this as well, thanks for the tip!
The big caps are reading about 28V-30V, Ill discharge them before pulling the board out.
The solider pads look pretty good from my view, a few might be on the thin side but most look fine. Ill have a better look when I pull the board out.
Are these fuse resistors represented by a different symbol than regular resistors?
On another note, the unit has been playing lately without engaging the protection relay ¯\_(ツ)_/¯. Is there anything that I can test while the unit is functioning correctly to help isolate the problem?
Thanks again all!
Christian
You can unscrew the heat sink from the chassis and then unscrew the amp board from the heat sink without too much hassle. My unit had enough room to get to the solder side once everything was unhooked. It looks much worse than it actually is.
looking back at my notes, I replaced several fuse resistors on that board. Make sure to measure those as they may have drifted off with time.
Thanks again all!
Christian
