Akai GX-630D Smoke?
Ifa
Hi
I have had this open reel since early mornings, last 20 years it has not been used. I've fired the deck up and played for about one hour with a great smile, good memories from the past did compensate for the "non perfect sound" in these digital perfect times. I was suddenly dragged back to reality of a burnt smell and light grey smoke emitting the deck, and jumped to the mains socket and ripped it out from the wall.
I have downloaded the manual, but I am not quite sure where to start looking for the source of the smoke. It did play all the time perfect, so I hope it still is ok. I have read in here that the CR1 to x noise suppressors might be burnt? Or any of the rectifiers might be blown. It did not smell any distinct like a electrolytic cap would do (at least in my imagination they smell)
I have opened the reel and had a good look, but I could not see any signs of burnt components, so I wonder if any guru here can give me a lead? That would be very much appreciated.
Check the power supply first, you might find an obvious offender (such as filter caps split in half).
Other components that have a history of being problematic are the R-C surge suppression networks labeled CRx where x is a number. These can be found on the GX-630D/DB Schematic Diagram No. 5-3 in the service manual.
Thanks a lot, I shall have a second look at these, and guess it's obvious if they are blown, either the resistors or the caps, tnx :-)
These will often have visible damage (cracks or burned areas) and/or a characteristic burned smell. If you need to replace any, they are available from many electronic component suppliers. Attached is a manufacturers specification sheet I obtained from the Newark Electronics website for similar components. The XE1201 type shown in this document has specifications that seem to match those of the ones used in the GX-630D.
I did not see any at the first look, but I have now a few locations to study closer. It is a nice reel to reel, and it would be a disaster if such a nice item are blown. For sure it brings the memories back for me :-) even if the high end hifi is not fully there.
Tnx a lot for this, I am currently offshore, and will have a good look when I am back home, and thanks for the link :-)
I did not see any at the first look, but I have now a few locations to study closer. It is a nice reel to reel, and it would be a disaster if such a nice item are blown. For sure it brings the memories back for me :) even if the high end hifi is not fully there.
Nearly all discrete components have modern replacements available, I would recommend Digikey or Mouser as a source of replacement parts.
The Akais of mine of that vintage have needed motor run caps, but that does sound like your issue. But I'd check them.
Hi there, I know this is a couple of years ago, mine did the same. Did you locate the problem? Thanks,
