hertzdonut
Press Play and Stand Back
Not that there's anything wrong with my current end panels, but I've been hankering to make a pair of new ones. I knew that I was staying with Walnut and wanted them a little thicker than 3/4". I also wanted to dress them up just a touch, with some laser engraving. We have an Epilog Mini, and I've used it to engrave a few things (including my iPhone!)
After trying a couple of things out, I settled on an outline of the Akai logo. I didn't want it to be too subtle, and decided to paint the lasered area black. After cutting and sanding, and then finish sanding (through the vertical sander at 180 grit), I taped off the area where the laser would do its magic. Taping provides the masking, and the laser burns through it and the wood no problem as you can imagine.
Here's the pieces fresh out of the Epilog. The crosshairs indicate where to drill for mounting holes.
A closeup--though the wood has been burned dark, I was concerned the stain might minimize it. Hence, the later steps
Painting...
When the coats were dry, time to peel away the mask.
Almost done peeling...
All done!
Time to sand and finish!
Painting...
All done!
