Urban legend or not ?
AKAI GX 747 dBx model sounds better ( rec,play ) than AKAI GX 747 model even when dBx function is OFF .
Data : GX-747 (1982-1983) and GX-747dbx (1983-1984)
The GX-747dbx is just like the GX-747 but it has additional dbx decode/encode pcb's - early DBX 2:1 Type I compression / expansion. The GX-747dbx was not a more expensive version of the GX-747. It was its substitute. Instead of LED bar meters, the GX-747dbx got back the more conventional VU meters. Akai probably had to omit the LED bar meters because the GX-747dbx otherwise would become too expensive with both dbx and LED bar meters in one set . Also the dbx version has glossy rosewood side panels compared to pine woodgrain veneer on regular 747.
