A few more notes on this circuit...
Reverting to the 6BQ5 in place of the 6V6 will necessitate replacing the 300Ω cathode resistor with the original 150Ω value used by Akai. A 180Ω resistor will also work and might be advisable with higher modern line voltage and less robust tubes. My circuit actually has two 150Ω 1W resistors in series due to my early experiments with both tube types.
The 6X5 rectifier that I used is the octal equivalent of the 6X4 used by Akai. They are essentially interchangeable, other than the socket. Be sure to use the same 0.6A filament winding for this tube that Akai did. The 6X4 and 6X5 are known for developing heater-cathode shorts if the filament winding is not separate and floating.
The 5KΩ and 10KΩ PS resistors were taken from the original Akai amplifiers.
Designing these amps to use the 6V6 like I did might also allow using the 12V6 by connecting the two 1.8A filament windings in series (if the amplifiers are built on a common chassis). NOS 12V6 pairs or quads can still be found at decent prices on the big auction site from time to time. I stocked up several years ago, and I'll probably need to make this modification in the near future. I'm currently running on a pair of 7408s pulled from an old Stromberg amp. They were well-used even before I got them.
This was my first scratch-built audio amp after returning to VT audio about 20 years ago. It lacks much of the "best practice" grounding that I employ now in new designs to preempt hum. The RCA jacks are grounded directly to the chassis. There is no star ground. The AC mains cord runs all the way to the front of the chassis across all the audio circuitry. LOL, I even realized yesterday that I had forgotten to ground pins 2 and 7 of the EF86s, so their internal shields are simply floating. Despite all this, both channels are remarkably quiet, and I probably won't bother to make changes.
It was my intent to hide all the ugly bits under the chassis when I built this. The layout and orientation of the transformers and chokes were carefully chosen to minimize the possibility of hum and interaction. Points to note are that A) the power transformers are at the rear of the chassis, well away from the high-gain stages, B) the audio output transformers are positioned such that their laminations are at right angles to the power transformers, and C) the PS chokes, which create very little AC flux and are therefore inert, are mounted up front.
Tape decks from this era typically saw much less use in terms of hours of operation than stereo amps and consoles. The original tubes are often like new. In addition, these particular Japanese tubes are superb. The 6BQ5s are extremely dynamic, and the EF86s give up nothing to the NOS British Mullards that I've occasionally auditioned in their place.
This amp is amazingly transparent and nuanced, and I highly recommend it for either headphones or high efficiency speakers. It was instrumental as one of the "discoveries" that convinced me never to return to SS. I'm sure anyone who builds this will feel the same. Good luck and happy listening!
Jack
