How do the magnetic antiskates compare to the other methods?
I read through a 1967 paper by Shure’s Chief Engineer James Kogen on the topic of tonearm skating. I was able to discover some interesting findings that the turntable/tonearm manufacturers didn’t get quite right in designing effective anti-skating mechanisms.
• Skating is the result of the friction generated between the stylus tip and the groove wall.
• The greater the friction, the greater the skating force.
• Skating is not the same as the centripetal force that is generated by the tonearm and the rotating record. (see Centripetal Force Graph)
• Using a blank record to set the anti-skating will result in a 5% error since this action is a demonstration of centripetal force and not skating.
• The skating force decreases as the tonearm travels toward the spindle. Skating is greatest at the lead-in groove and curves downward to its lowest about 15 mm before the lead-out groove. This is the opposite of centripetal force since that force increases as the tonearm gets closer to the spindle. (see Skating Graph)
• Most turntable mechanisms calibrate the anti-skating force to counteract the centripetal force of the tonearm: Increasing anti-skating as the arm travels toward the spindle. This includes mechanisms using springs and weights. So, for most tonearm designs, too little anti-skating is applied at the lead-in groove and too much force is applied toward the spindle.
Summary:
• The blank record test shows the centripetal force of the tonearm which does not reflect the actual skating force. Stylus shape has no effect on centripetal force but radius size does.
• The stylus must be tracking in a record groove to create skating. It is depended on stylus shape as well as radius size.
• Centripetal force increases as the tonearm moves toward the spindle.
• Skating force decreases as the tonearm moves toward the record label.
• Tonearm anti-skating mechanisms are designed to counteract the effects of centripetal force; increasing as the tonearm moves toward the spindle.
• It is not known how the mechanism is calibrated: Is it an average, minimum, maximum value? What stylus shape is it optimized for?
• Assuming the setting is the average force across the record; the initial setting will be lower than the optimum force and higher as the tonearm moves toward the spindle.
• Re-adjust (lower) anti-skating settings is necessary as tonearm bearings become worn and dirty.
• If “less is better than more”, use a line contact stylus and set the anti-skating amount ¾ to ½ of the VTF amount. Anti-skating will be insufficient at the beginning but will be a closer match as the tonearm approaches the middle of the record. This could be totally off base depending on the design of the tonearm mechanism.
I’m not a perfectionist and I’m not going to lose sleep over this. I suppose it’s the best tonearm designers can do. It’s like cartridge alignment: There are only two points on the record where the alignment is perfect and we just live with imperfection for the majority of the record. With anti-skating there is probably only one point were the forces are perfect; and that lasts for less than a second.
One reason I'm interested in LT arms is this.Good arguments for linear tracking tone arms. They do work if maintained and used properly. VPI was against anti skating for years and Harry always said if you did use it much less was required than most people thought.
What a correct anti-skating design would look like for various mechanisms.How do the magnetic antiskates compare to the other methods?
Spring: As the tonearm travels toward the spindle, the spring should slowly compress. The spring should be fully extended when the arm is positioned at the edge of the record.
Weight: As the tonearm travels toward the spindle, the weight should slowly drop and hang from its lowest position at the end of the record. When the arm starts playing at the edge of the record, the weight should be hanging at its highest position.
Magnet. The force is strongest when the poles of the magnets are close to each other, therefore as the tonearm travels toward the spindle, the space between the two poles should move further apart.
Of all the designs out there, the magnetic mechanism seems to be the easiest to tweak to make it work correctly.
This is how I feel with EQ's...lol.Yeah. I'll never understand this mentality. It certainly can't add to the enjoyment of playing music. Takes tweaking to whole new level.
Dealing with analogue playback problems like this, tip alignments and wear, timebase instabilities, mechanical resonances, and the others is what many folks found compelling of the potential of digital storage when CDs appeared.
I'm one of those who still wonder at how well it works, and as a time machine miracle of moments permanently frozen, to be recalled at will, anytime.And then there are those of us who enjoy playing records on pre-1930 equipment as well as stuff from the 1970s and 1980s.
