You don't need to potshot, especially when you try to put words in my mouth.
Let's review the words that came out of your mouth:
It is just plain, utterly wrong. No gray area, or debate need apply."
Reasonable folks would call that arrogance in response to what a distinguished colleague says he measured.
First of all, I have no idea if you have properly conveyed FVA's thoughts here.
I did better - I directly linked to his own words in post #105. No need to find that post, I'll include them here:
As I have explained many times, the problem with "scientific" A-B amp testing is that the amplifiers are connected to a common source and then into a speaker switcher, which can switch either amplifier into the speaker load.
What the ABXers fail to understand is that the distortion characteristics of an amplifier are reflected back into its input jacks because the feedback loop contains these distortions. Since the inputs of the amps are being fed from a common source, the sum of the distortions of both amplifiers are present at the input of either amp being used. Thus essentially both amplifier under test under these conditions will sound the same, and generally the overall sense of the listening session is unsatisfactory, for good reason...
This process eliminates the ABX common input issue which has clouded so called "scientific" listening tests for years. Of course the ABXers don't believe us, but they are too pig headed to make the simple measurements to the amplifiers to show themselves that the distortion is indeed appearing at the input jacks. It is..."
Make the simple measurements to show themselves that the distortion is indeed appearing at the input jacks.
For brevity, I skipped the middle section outlining his test procedure that eliminates the problem.
I was surprised to hear them come from a respected engineer such as he, so I suspect there is some misinterpretation in your description. Do you have a link where I can read what he says directly?
No doubt. Have you measured the effects like FVA?
While some may call me a "subjectivist", I'm actually an observationalist who walks both sides. I don't discount science and measurements - only bogus science and extrapolation of simplistic metrics
assumed to provide correlation well beyond their ability. Ever heard the Crown ICK-150 preamp with its wonderful THD spec?
I measure what I can. My speaker placement was assisted with lots of level measurements in the bottom three octaves for the
best neutrality (yes, it has only third octave resolution). I found an
interconnect AB test here (scroll down a bit) and decided to duplicate and
measure the results for myself. Bogus *science* for sure! (note: while the forum sometimes underlines words for marketing, please recognize I've placed three links within this paragraph)
Also, people are often sincere, but mistaken. I sometimes am, at least. It would be odd to go through life feeling deceived by people who were simply misinformed.
A truly professional stance (yes, I thought you read the link on which I based my comments given the participation in the discussion) would have been a bit more measured that yours I cited above.
