Nikkoholic
Purchased a Vintage Nikko Alpha 450 and when I hooked it up the left channel is all static and no sound. I can play with the volume on my preamp and once I "overcome" the static it seems fine. But if I shut it down and turn it back on and keep the volume low the problem returns. I have to really crank it to really high volumes to overcome the static so this is dangerous (to the speakers). The problem is in the left channel. Right channel does it a little but not nearly as bad and clears up with moderate volume levels.
I swapped speaker wires L & R problem stayed with the left channel (moved to right speaker). Tried speaker B outputs same problem. Switched back to my current amp and no problem (just to make sure I didn't have a bad cable or loosen something when swapping out). I also changed the direct / normal switch on the back, no change (this bypasses the line input level pots on the back of the amp).
I searched the forum for about an hour to try and find a post with similar problem and couldn't find one. I did see the excellent artical on the Deoxit process.
However there aren’t many contacts on this amp (I think) just RCA in, Power, Speaker select (but since the problem remained using both the A and B outputs it doesn't seem to be in this switch.
I'll try the cleaning process this weekend, but what else could be causing this? It did just finish a long journey (professionally packaged) but it was claimed to be working when it left it's prior home. I am electronically challenged, but can do the deoxit process, but that's about it. But while I have it opened, is there any other easy things to look for or observe?
Note when it works it seems to be fine.
Thanks
Thanks
