Nikkoholic
So I left it on for about 2 hours. Came back and things seemed good. Still if you pushed "lightly" on any of the relays you could get the bad signal again.
So here is my logic and what I did:
The main PCB is mounted toward the bottom of the amp so all the component are facing the bottom of the amp. The solder joints facing upward. The bottom cover of the amp when installed is only about 1/8" or 3/16" away from the plastic relay covers. So my thoughts are in shipping (despite how great it was packed), if this thing took a good slam it is possible the relays got a bump / slam too. So with that thought and the fact that when light pressure is applied to the relays I'm figuring possible fractured solder joints.
I was able to the the circuit board out far enough to expose the solder side, but could not get close enough with a magnifying glass to really inspect. So I just went ahead and reheated each connection on each relay. I only hit each connection 1-2 seconds just enough to re-puddle the solder.
Turned it back on and still had similar problem but not near as bad. So one more time resoldered this time just coating my iron tip with solder. Turned it on again and so far no problem. I'm letting it cool down and will restart again in a while; I'm a skeptic at this point, but very hopeful.
Left channel still seems a little more quite than the right, but isn't that typical of most recording. I'm paying attention to things I hadn't before, so my mind is mush.
Does this make sense and does any think this could have been the problem? I'll update you shortly.
