Hi,
I just scored an Allied 333 (for $5!! + 1 hour drive). It's my 1st tube amp. I have some experience with restoration/recap of solid state units but tubes are new to me and they seem to be coming with totally different set of problems to resolve.
I was very excited to see that my Allied 333 actually started without any issues on full 120V and only required pots deoxit. It has all original parts (incl matsushita tubes). No smoke, hum, no distortion, super nice, clean sound. I was really excited to hear it sing! Played it for several hours last Sunday till late night from Spotify until my phone battery gave up ;-)
Then next day I watched some videos of tube amp caps blowing up in spectacular way and figured out that maybe I should take some precautions to prevent that.
Since the unit seems to be working fine - I am not interested in fully overhauling it. Just make sure it does not blow up. I have a couple questions with regard to that. Maybe somebody can help:
Basically my plan for now is to swap out only electrolytic caps.
- Are there any other items I should consider that can blow up and burn? (e.g. resistors etc.)
- in general it's safe to put bigger than required voltage caps than into solid state as long as capacitance matches. Does the same principle apply to tube amps? (they operate on voltage so I am not sure here)
- should i be aiming for 105 Celsius rated caps all over or are 85C good as well?
- my plan is to use Nichicon audio grade - are they considered to be "good" for tube models? In terms of preserving the original sound. Or maybe there are better brands?
- can I safely replace axial leaded caps with radial lead
- PIO and ceramic caps - do I leave them alone or swap out?
- will I need to re-bias the tubes after the capacitor swap?
- the unit has 2 big, silver Nichicon caps on the top. Each of them has 4 legs marked YXUO. Does this qualify for replacement as well?
- should I consider buying a variac and use it permanently when powering the amp on or will it be able to hold instant 120V?
Thank you,
-Peter
Thank you,
-Peter
