Arrgh, Just my luck...
Been repairing a Harman Kardon HK 450 with a couple of faults that was solved. Changed transistors and caps in the Pre-amp.
Sounded great and was just about to finish it when disaster struck.
Had cleaned all the pots and wanted to test if the scratchiness on Bass and Treble had went away.
Powered on the unit and put one of the plastic knobs on the Bass shaft to test, no problems there, removed the knob to try the Treble, sounded good, but then while I was pulling away the knob from the Treble pot shaft to test the Balance suddenly a big BANG came from the speakers and a LOUD crackle / frying started from the Right Channel...
Powered down, put it up on a Dim bulb and with Speaker switch disengaged no faults.
But as soon as the Speaker switch was engaged the DBT becomes bright with a pulsating movement from weak to bright, the Loud crackle started on the Right CH and a weaker kind of pulsating woom can be heard from from both Channels (kind of like the "Welcome hum" in the NAD 3020).
What on earth could have caused this by just removing a plastic knob from the Treble? was it shorted against the faceplate or something?
How does one go about to troubleshooting this?
