Alps 12 pin Marantz 2285B replacement options.
Deloryan
So I have a bad Speaker select switch in my 2285B. I ordered the black replacement from Digikey and it does not want to fit the dimensions. Does anyone know where I can find a better replacement? Thanks
There is a smaller size of those selectors but you should check the datasheet to see if they are too small.
