I'm pretty sure it needs to be significantly reduced in value, if not removed altogether.
Please post pics............... we love pics!![]()
I used some small needle nose pliers to remove mine
That said, any oxidation of the screen changes it's acoustic characteristics from the original spec, and that's not a good thing.
Thanks for this input gents.
Elitopus, when you say you used needle nose pliers to remove them, does that mean you reached through the hole to simply grab them after separating them from the horns... Or did you have to further disassemble the drivers to get at the screens?
Correct, I removed the driver from the horn and pulled out the screen with pliers. I use a little pull and turn action to make sure the screen comes out of the groove without ripping.
It takes about two minutes to do both drivers once they are free from the horns.
Thanks for this - I wonder if our drivers aren't configured differently. Were the screens on your drivers mounted on the outer surface of the magnet body, i.e., exposed when you separated the horn from driver?
I was doing some research last night and I think I know why I was having a hard time understanding this operation... The screens on my 806a are located on the inner end of the cylindrical magnet, i.e., inside the driver. So when I separate the horn from the compression driver, there's no screen on the outer surface of the magnet... The screens are mounted flush against the inner wall of the magnet...~4" away from the visible outer surface of the magnet, accessible only through the ~1" diameter x 4" long cylindrical cavity of the driver.
Were your screens positioned this way? I'd think the risk of debris falling into the driver body would high if one were to reach through the magnet body with needle nose pliers, grasp the screens at the center and pull...
Yes the screens are mounted like you said, within the body. I took some long, small needle nose pliers and reached in there and grabbed the screen. I held the driver above my head so the debris would fall out and not into the phase plug.
If you are worried about debris you could always takes out the diaphragm and then clean the gap/phase plug area afterwards.
I also have some Emilar drivers which have the screen on the mounting gasket. Now THOSE are easy to descreen![]()
Here are a few pics of my project so far... Hoping to finish in the next week or so.
Boxes and baffles are stained here, but not yet finished - planning too use Waterlox to finish them.
View attachment 897268 View attachment 897269 View attachment 897271
Thank you! I appreciate the kind words! Still have a ways to go!DANG son, that's mighty fine work!!!
Are you saying I did them right...or good?The xovers are looking good. I like how you spaced the components, especially the inductors.
Are you saying I did them right...or good?![]()
