Valveglow
Dude - fire away. See my avatar...dual 414z loaded cabs.
I have seen them in the thread as they progressed, "liked them", and now I love them!! Incidentally, those cabinets are gorgeous!!
Thank you - they were really born more out of (financial) necessity than anything else. They're refinished 9844 monitors that I installed new baffles into. They do sound quite good! Feel free to ping me with questions. I had quite a few as I worked through the project and really benefited from the kind folks here on AK...I've learned quite a bit and happy to share anything I can.
I just spoke to Bill at Great Plains Audio. They took a close look at the 806as, tested them, regaussed, and have not been able to find anything wrong with them or to replicate the distortion. He said they look pristine.
So the question is obviously...what could be causing it? I've never heard this kind of distortion from my system before - it only occurs in a narrow frequency band and is only particularly audible during quiet passages during which those frequencies are prominent, e.g., a quiet trumpet solo. Obviously the first thing I'll do is switch the drivers to opposite channels - I stupidly did not do that before sending them off because the nature of the distortion sounded so mechanical - rather than electrical - to my ears.
It almost sounds as though there is a vibrational quality to the distortion.
The distortion is such that you can still hear some of the source tone that is causing the distortion, but not much, and it is more of a true distorted sound, rather than static or electrical noise being introduced.
I really hope Bill is right, and it isn't the compression driver, but what worries me a bit is that the distortion seemed to become slightly more noticeable and perhaps louder after I cleaned the voicecoil gap and reseated the diaphragm.
Anyway, assuming Bill is right, and upon switching the CDs to opposite channels the distortion remains on the left side (and does NOT follow the driver in question), to me the next most likely suspect is the crossover, especially given that I made them.
Does the nature of the distortion I'm describing sound like something that could be caused by a faulty cap? Or a bad inductor? Poor soldering? A broken wire inside the sheathing of the inductor input/output leads? (this seems a possible suspect come to think of it...portions of the inductor lead wires were stiff to the point of feeling hardened or brittle (although they did not crumble or anything).
Anybody ever heard this kind of distortion from a compression driver before? Anybody have a guess? The caps are all new, I'm using the original inductors. I did not have the 30923 networks installed during all this. As always, I'd appreciate any help or guesses - educated or otherwise!
Just FYI for posterity... The distortion I was getting was the result of the diaphragm just slightly being a bad fit for the driver. Swapped it into the other driver, no more distortion at 4k.
I love what you did with your 9844's ( BTW ) !!
( Hope you don't mind a couple more questions ):
I realize ( from another post ) that you eventually retired the 806 drivers in favour of 802s .
Did you migrate the original diaphragms from the 806s into the 802s ?
Was the ( rectified ) 4K distortion problem exclusively an 806 occurrence ( or did you also have a distortion problem with your 802's ? ) ?
FYI, here's the distortion profile for 2, 802T drivers of mine .
The second driver shows a significant distortion problem ( even at low drive levels > note the cursor positioned on 4.4K ).
These diaphragms have no "play" what with the guide-pins and holes being a tight fit.
Historically, if swapping the 2 diaphragms around won't fix the distortion problem then I'm left with no other recourse than to enlarge the guide-holes ( on the diaphragm ) from 1/8" to 9/64".
- This enlargement gives enough "slop" to properly adjust ( or mis-adjust in most cases ) the diaphragm within the gap.
One wants to have test software like REW & associated test mic to pursue this sort of DIY fix to distortion problems .
First to Jaaronb (or anyone else who happens to know): When using two 414 woofers per cabinet (since I possess the innards of an Altec 9844 system, without cabinets), what cubic footage do you make your boxes? Are they about the same sized enclosure as the Altec 9844 including the 811 horn with driver? Bigger? Smaller?
Next, I recently purchased two 802-8G II drivers, two 416-8B Woofers and two 1200 HZ crossovers from Great Plains Audio to eventually recreate a Model 19. Can anyone tell me about which diaphragm is used in that 802-8G from GPA?
I currently use two 414z drivers in 9844 enclosures with the horn/compression driver on top. I want to say I've seen somewhere (but can't remember where) a discussion that indicated the ideal enclosure size for two 414z drivers was larger than the 9844 - I think ~7-8 cu ft, if memory serves. Whereas the 9844 is only ~5 cu ft. That said, my room is *terrible* with very low <7' ceilings, so I honestly don't know what my speakers would sound like in a decent room. One of these days I'm gonna take em upstairs when the wife is out of town.
I just did the math on the Altec Malibu, which uses 2x414z per side... It's somewhere in the neighborhood of 7+cu ft. You could always just build Malibu cabinets from the plans....
I don't remember the model # of the diaphragms used in the GPA 802 models, but I'm almost certain it's the same one GPA provides as a replacement for 806s, 802g, et al.
Unless you're planning to use them for sound reinforcement, I suggest removing the loading caps from your 802s and putting a layer or two of felt in the back of the compression driver "lid" that bolts onto the back. You'll have to either clip the length of the three bolts that hold the loading cap/diaphragm to the compression driver body, or just buy some stainless new ones that are 1/4-1/2" shorter. I totally forgot (for months) that GPA shipped compression drivers with loading caps installed, and recently removed them from my 802s and 604e's.
You'll get a a nice improvement in overall HF extension and openness in the HF by removing the loading caps, which only serve, as I understand it, to increase the safe power handling of the 'phragms. Usually only necessary in PA applications.
If it matters at all, my 414 is the "Z" version. Also, I only have the EXTERNAL dimensions, but the the 9844's total volume including the horn is 31" x 24" x 16", which is 6.888 cubic feet, not 5. Again, we're talking external dimensions, but we're pretty close to that 7 you suggested. Thanks J!
You're correct about the external dimensions of the 9844, but believe it or not, when you calculate the 9844's *internal* volume, by subtracting just 1.5" from each of the outer dimensional measurements to account for the 2*.75" plywood walls on each dimensional measurement, you get 5.56 cu ft. And that's not accounting for internal bracing, the volume occupied by the speakers themselves, etc.
I was shocked the first time I calculated the internal vs external volume of the 9844, also thinking I was "close enough" to 7 cu ft. I thought that measley 1.5" was basically a fudge factor.
The figure I stated above for the Malibu was my calculation for it's internal volume, subtracting that 1.5" per side.
None of this is to say the 9844 cabinets sounds bad - they sound great! Just passing along one of those eureka moments I stumble upon once in a blue moon....
I found some pics of the Altec Malibu. GORGEOUS!! Were they ported?? Don't see a port...
http://www.audioheritage.org/vbulletin/attachment.php?attachmentid=28915&stc=1&d=1191900237
http://www.audioheritage.org/vbulletin/showthread.php?18580-My-new-Malibu-s/page2
http://www.usaudiomart.com/details/...r-audiophile-hifi-16-ohm-vott/images/1428811/
Interestingly, I saw one with a so called Malibu that had a rectangle slot - port in the front, but with a 15 instead of two 12s per cabinet, in the same looking cabinet and grille...
I believe they did a funny trick with the port on the Malibu, and the early Valencia models also...the opening on the front baffle where the horn fits in - where the 'face' of the 811b horn is affixed - is 'too wide' by xx inches per side on the vertical, leaving an opening on each side of the 811b baffle of a couple inches. These two openings, one on each side of the horn face, sum to the appropriate port size for the tuning the Altec engineers wanted. Google images of the Valencia or Malibu, and from the rear, you can see the slot openings on either side of the horn.
There have got to be more knowledgeable people than me around here. Where are you nerds? I just started learning about all this stuff a year or two ago. And I dated my high school math teacher for an 'A' (heh), then took 'formal logic' as the math requirement for my English degree.
Here's a pic where you can see the 'ports' I'm referring to:
