gdmoore28
Thanks so much! I appreciate the thought.Sorry to hear this, hope recovery is fast for you
GeeDeeEmm
No worries at all! Reminds me I have a nodule I need to get checked that turned up during a lumbar MRI a few years ago. The referral for the nodules is a CYA/SOP...they refer everyone with appearance of one to avoid malpractice lawsuits down the road. They're common and extremely rarely anything to worry about.Just back from the doc. Confirmed broken rib, and she's sending me for a CT scan because of some "nodules" on both lungs. Danggit. Something else to worry about.
Sorry, Aaron, for drifting away from the subject at hand! I'll try to restrict myself to speaker issues henceforth.
GeeDeeEmm
Sorry to see this turn of events. GPA's turnaround time is pretty good, and you know things will be right.
Things are busy in my world so my posting opportunities are limited. I've gotta catch up on GeeDeeEmm's build, he's also headed in a pretty rewarding direction and will have some substantial speakers when he gets it worked out.
Aaron, I'll bet your crossovers are fine. Maybe somebody will correct me, but I can't conceive of anything in the crossover that would cause distortion in only one single frequency range. You'll be able to test this once you get them back and see if the problem is still there. If so, swapping sides will tell the tale.
The other day when I was doing my testing I thought I could detect a similar distortion from my horn. I used the old mechanics trick. I used a stethoscope to trace the distortion to a mechanical rattle being induced by the cabinet.
I have also heard this distortion before. On my last setup with large format horns. I only noticed it on certain songs and certain frequencies. Especially stuff like piano or classical music.
I took the drivers apart to look for any defects but could not find any. I have had diaphragms come apart before, and the usual junk in the gap. That wasn't the case with these drivers.
I would do a sweep on those drivers and not be able to duplicate the distortion. It was on both drivers, but more on one than the other. It was such a pain to move them around that I never swapped them from side to side.
Horns (and Altec especially) are so reveiling of any flaws in upstream components. I just recently replaced my CD player because it was causing a hiss in one channel. Also the balance seemed off. I don't think its something like that, that is causing your problem but you never know.
Like was mentioned above, you might have a horn that is vibrating against the cab at a certain frequency. Or something like that.
Have you listened to your problem song with the 806 driver not attached to the horn?
I was not expecting the 3uf Jensen PIO caps I got for the 30923s to be roughly the size of a smoke grenade....
I'm still here, as addicted as ever. You got questions?
