Altec 890c recap question
Raru
Member
So thanks to a fellow AKer i know that i will need two caps at 6.0uf 50v and 1 at 30uf 25v but i cant seem to find any Daytons with those values. Can anyone point me in the right direction?
You could use 2 Carli Mylar caps in parallel to come up with that 30uf value and get one for the 6uf. Or a 5%DF quality NPE for both values. Sometimes going to the Metal Poly caps will significantly reduce ESR.
acessing inside altec 890c
Raru - tell me how you were able to remove the woofer and access the interior.
Set cabinet with terminal end down. Remove 4 screws holding driven woofer ( closest to the end of the cab with the terminals)
pull woofer out.. crossover is right there.
