miscrms00
Just as I finished getting my Altec 1608As repaired, recapped, and ready to go back in the rack plans changed.
http://audiokarma.org/forums/index.php?threads/any-hope-for-this-altec-1608a.683434/
I came across a pair of Altec 9440As at a good price on ebay, and the seller turned out to be just down the street. I had been missing the one I traded off a few years ago, so it seemed like an opportunity not to be passed up. And there was no doubt these pack a lot more punch into a lot less rack space than 1608As, even if they do lack the iconic green fronts. These were the last two of a dozen or more that had been used in his professional sound event company, but had been long since retired for most events by newer more powerful amps. Funny thing, when I got there I realized he was the one whose stickers had been on some of the retired Altec/JBL gear I had previously acquired from ASU, as he had been the local dealer / service center for Altec and JBL for many years. Pretty cool!
I was not disappointed when I picked them up, aside from some minor scuffs / blemishes they were very clean and look to have been well maintained as well as very close in serial numbers. DC offsets were not very far out, but I was able to dial them both in to about 1mV or so.
I've already had the opportunity to do some stress testing on these amps in the course of my recent Intersonics ServoDrive Contrabass rebuild, and they seem to be working like a champ even with sustained continuous sine waves at 100% output into a 3-4 Ohm load.
http://audiokarma.org/forums/index....servodrive-contrabass-rebuild-attempt.754517/
Never the less, it seemed like it would be a smart idea to go ahead and replace the electrolytic caps before putting them into daily service, as the owner couldn't really say when they'd last been done due to their semi-retirement. So here's what I've ordered. I decided to go mostly with a Vishay series similar to what I used in the 1608As which come from a legacy Philips plant in Austria. Although this time I decided to step up to the 138 AML series from the 021 series to get 105C temp rating. They were not cheap, but I wanted to stick with axial and with what digikey has in stock. In some cases I have gone higher in voltage as these are physically smaller than the originals, often have better specs, and are sometimes cheaper for some reason.
Control PCB:
C2 10uF 50V: Vishay 138 AML 10uF 100V
C3 200uF 25V (radial): Kemet ESY 220uF 50V
C5 100uF 50V: Vishay 138 AML 100uF 50V
Driver PCB (x2):
C1 5uF 25V: Vishay 138 AML 4.7uF 63V
C3 50uF 16V: Vishay 138 AML 47uF 40V
C5 10uF 25V: Vishay 138 AML 10uF 25V (ordered extra 100V too if they fit).
C10/11 10uF 100V: Vishay 138 AMl 10uF 100V
Chassis:
C1/2: 9800uF 100V: TDK EPCOS SIKOREL (Siemens) B41550 10,000uF 100V
The pair of main PS caps were pretty painful, but I figured I want to keep these amps a long time and the 20,000hrs at 105C sounded pretty good.
Last time I did a 9440A I used the B41456 line, half the cost but "only" 12,000hrs at 85C. They are also only 2" diameter so they took some finagling to fit in the 2.5" holders. The B41550 are proper 2.5". All in all about $220 worth of caps from digikey, not terrible I suppose for 2 amps. Actually less per channel than I spent on the 1608As if you want to look at it that way.
So anyway, once the caps arrive I'll plan to trace things out and check resistors, voltage, etc along the way to see if anything else looks suspect, but I don't expect to find much given how well they seem to be working.
Here's a few pics of the internals to get rolling:
Control PCB:
Driver PCB (x2):
Chassis:
