Only 10 watts / channel more for the Technics, plus a lower damping factor compared to the NAD (40 vs 100). You need to explain what the issue is - what do you mean by 'all the sound I pure static / wind'?
well I’ve had my doubts about this reciever mainly because I found it on the street… but maybe it doesn’t work
Yeah feels bad but it was worth a shot!Ouch!!!
Thanks! I was just afraid that I might just end up frying them. Appreciate the help!
It will probably work. Depends on how much they are asking for it and if it is in good condition. That isn't going to be a powerhouse by any means so I would avoid overcranking it and blowing up some tweeters...
Do you Think the technics Would function with Them?
Hi I’m in the process of buying a pair of b&w 630i.
,when I connect that receiver all the sound I pure static/wind..
You ideally want some good clean power with those B&W's and also you need to resist the urge to just keep "cranking it up" until you fry something...
OP, how much do you want to spend? Are you trying to do this on the cheap?
