Amp Selector switch
Jeff Howard
Hello All,
I have two amps that I'd like to run to 1 set of (2) speakers and be able to switch between the two amps. As I use them for different purposes: Music vs. Movies/Sports.
Is there a switch made for this? I was thinking of using a 4 pole changeover switch or something like that.
Let me know your thoughts.
Thanks Audiokarma!
Hello All,
Thanks Audiokarma!
There is a thread on this and I've posted the schematic for the simplest way to do it that would allow you to use either amp with either pair of speakers, even simultaneously.
https://www.audiokarma.org/forums/i...switcher-for-test-bench.893353/#post-13273991
This model was mentioned in another forum recently. It should fill the bill perfectly.
https://www.soundandvision.com/shop...comparator-crossover-router-sjfgh5y8km-p.html
I like the look of this switch but it seems expensive for the purpose. Is there a drawback to using a toggle switch like posted above?
Shouldn't be but what would concern me is how resistant a home brew device is to cross connection of amplifier outputs which of course could potentially result in disastrous consequences. These units are designed specifically to safeguard against such an occurrence. Just make sure you know what you're doing.
If you're talking about two amps, with the speakers going in the box and one coming out, use this JEC TC-616 in reverse. Break before make. $25.
