My problem is I have hundreds of other things I also want and so I prioritize, even a cheap signal gen would have limited use at this stage of my audio journey. The sound card though limited if understood still tells me enough to feel I’m getting reasonably good audio output. Clipping, good rise time, acceptable tilt, exact wave replication, nothing added. I guess my goal was to just improve on my stock Magnavox 8802 using established mods and methods, my test measurements are used to verify I’m getting the desired results, or adjust. The stock transformers wouldn’t allow this wide of a response at similar output levels, scope verified. When listening to the amp I get the wonderful 8802 sound, now extended well past my hearing range and it can drive my JBL L19s easily to the listening levels I prefer. I'm usually at 1/4 to 1/3 volume range using just a passive attenuator, which is giving me 30 to 20k clean. I guess back to my original question, no the Mac mini sound card isn’t capable of testing to a 10khz square wave, or even a good 1k. So I will have to wait and see if my transformers can reproduce a 10khz square wave for now.
