john_w
Miscreant
Yet another thanks for the great procedural info on this topic, Echo!
I've done a little home electronics repair myself -- got a degree in E.T. and all that (actually, decades ago) -- but I would no doubt have missed a step or two on checking the offset.
I asked a new tech that I tried here in Denver to check these levels on my Sansui AU-919 while it was in for an unrelated problem, since it also seemed to be running a little extra hot. When I got it back, I asked about it, and he just shrugged and said that neither channel seemed to run hotter than the other, so he assumed it was OK.
He also recommended AGAINST replacing the original supply caps in my AU-9500 ('72 vintage), unless and until I start hearing 60 hz hum in the output.
Does this sound right to any repair gurus out there???
On the plus side, he did do a heckuva cleaning job -- used Deoxit and all that. And he seams to do good work with intermittant problems. But then, he also has a 4-month backlog.
It sounds to me like it may be time to re-assemble my old Fluke meter, replace the batteries, dust it off and actually do something with my own gear. The old addage holds true once again: "If you want something done right..."
