dc output not causing protect mode fault?
newbie here and electrical klutz.
this has got to be 1 of the coolest threads i've ever read. almost like disclosing insider information to the commoners. just like computers, a little info shared - ("knows just enough to be dangerous").
course, i ran right out and bought the 29 range radio shack multimeter (radioshack.com has it on sale $10 cheaper).
hastily i bought a sony 100watt '82 model ta-f555es amp on ebay without prior research for $91. later found out it has a history of protect mode issues.
with 1 set of brand new speakers -
sure enough, the fault can occur as low as 10 o'clock with heavy bass passages. even occurs with tone defeat at 11 to 12 o'clock. speaker sensitivity 97 db @ 8 ohms. 14 gauge wire.
tried everything from cleaning, to a cooling fan, to every hookup possible (different speakers - ala avid 8" bookshelves), to new speaker wire, to monster interconnects, to all the inputs (only source i'm using is a cd player), to the ohm switch on the back set to 8 & 4.
nothing is plugged into the switched or unswitched outlets and the amp is plugged directly into the wall.
surely i might have a dc output problem but my readings were:
left: -1.15 millivolts right: -.07 millivolts
sony calls this an "audio current transfer" current drive amplifier system which has electrically separated the 4 amplifier sections.
the amp sounds pretty decent to me but just when the music gets good, i'm thinking anytime now and ouch - 95 mph down to 0 in 0 seconds flat... ugghhhh!!!!
i got what i payed for...
anyone know of a cherry au-717 for sale? by the way, noticed the au-717 has twice the slew rate and power consumption as this amp.
