macaltec
Metal Master
The offset is not stable in either channel. The protection does not trip in any sort of pattern nor in response to output level. It will sit idle with nothing hooked up to it and not trip. I can uncouple the amp/preamp sections. I'll need to seek the help of a knowledgable friend to track down the output before the protection circuit. I've got the schematics but aside from the bloody obvious I couldn't find my :butt2: with both hands. Thanksgonzothegreat said:Is the offset stable in either channel? Does the protection trip in a regular and repeatable manner? Will it idle (i.e no music) for long periods and not trip? See if you can find the amp output before it gets to the protection ckt and see what is amiss. Can you disconnect the preamp from the amp?
EW - Could this be a protection circuit issue? Or is it more likely an amp problem?
Theoretically it could be something as trivial as dirty pots. Swap 'em out for multi-turns and if that isn't the issue, you'll be glad you did anyways.
mac
