ilimzn
Well-Known Member
Haoleb said:Well, i have this sansui au-517 sitting in my closet because it has distortion and its protection kicks in after like 5 mins. so i tested the dc and in one channel it was 80 something mv and the other was like 230mv Is this why i can hear distortion from the amp and why after a few mins the protection kics in?. what do you think i should investigate first to try and fix the amp??
It would seem this is the dreaded VAS stage emitter resistor problem -common on AU517, 717, and the odd 710.
Look for 2 transisotrs on the power amp boards, 2SC1904 and 2SA899, they are black square types (TO126) and are mounted vertically on the board. In the immediate vicinity you will see two small greenish-grayish-whiteish resistors rised off the board surface via their legs being formed as spacers. These are metal film 150 ohm, though you will likely hardly be able to tell as they tend to overheat and change value, or go completely open. You need to substitute these with same value (150 ohm) about 1W, also mounted off the surface of the board for better cooling.
When these go open the amp will stay in protect mode due to sticking to one supply rail. When they drift too high up in value, offset will increase to the point where the protection may cut in and out intermittently, or cut out completely when they warm up. Distortion will increase drastically.
One of these resistors is often also covered with the famed Sansui corrosive glue, and tends to fail first - the one which is close to one of the 470uF local filter caps (on the power amp board).
I serviced a number of amps from this series (OK a large number) and would routinely change these resistors even before doing any other work, whatever it may have been.
ZN
PS, of course, after these are changed the amp will require a readjustment of bias and offset!
PPS: see attached schematic, sorry for the quality, this is one of my reverse-engineered hand-drawn diagrams...
