Amplifiers all sound the same
Status
Not open for further replies.
OP, your observation is valid in the realm of insufficient experience.
Just because you've driven a Ford Taurus, Chevy Malibu, Toyota Camry, and Dodge Charger (fleet versions) doesn't mean no car can go faster than 15 sec in the quarter mile, have better than just a comfortable ride and no better than decent handling.
Take two class A Thresholds and call me in the morning.
(...) amplifiers pretty much all sound the same. I have tried very hard to hear differences, but honestly I think I'm just trying to convince myself.
It's been a confusing thread because you're not just talking about amplifiers. So far, you've mentioned listening to 5 receivers, one integrated amp, and 3 actual amps. (let me know if I'm leaving something out)
These are receivers you've mentioned hearing:
Denon AVR-4802
Integra DTR 9.9
Sansui 1000A
Denon AVR-4802
Sansui 5050
This one is an integrated:
H/K PM655
and these are amplifiers:
GFA-5500
Marantz 170 DC
T-amp (although this could have a preamp section in it depending on the model and may count as an integrated if it does)
So the title of this thread is confusing. And most easy to confuse with the infamous article(s) where amplifiers (not receivers or integrateds) were compared and the consensus was that there was no audible difference. But you're saying something else; you're saying all receivers sound the same as integrateds and amps; the whole scene is full of sameness.
I too think you need a larger sample. I'd put all of this gear you list on more or less the same level of performance. And there are gains to be made up from there. But first, you'll need to sort out what exactly the gear is that you're comparing does.
Denon AVR-4802
Integra DTR 9.9
Sansui 1000A
Denon AVR-4802
Sansui 5050
H/K PM655
GFA-5500
Marantz 170 DC
I'll try and update the list you've started with everything I can remember.
Receivers:
Denon AVR-4802
Integra DTR 9.9
Sansui 5050
Onkyo TX-4500
Sony DA3000 ES
Sansui 771
NAD 7600 PE
McIntosh 4100
McIntosh 4300v
Marantz 2215b
Marantz 2220b
Marantz 2230
Technics SA-400
Kenwood KR-8010
Sherwood S-7900A
Sansui G-4700
Harman/Kardon hk350i
Kenwood KR-7050
Onkyo TX-SV50 Pro
Integrated:
Harman/Kardon PM655
Luxman L-480
Scott 480A
Yamaha CA-610 II
Luxman LV-112
NAD C350
Pioneer A-27
Amplifiers:
Marantz 170 DC
Adcom GFA-5300
Adcom GFA-545 II
NAD C270
Pioneer M-25
Sansui B-2101
Carver M-1.0t
More could be added to this list as I have listened to other amps, but I can't remember the models and I don't track the models of equipment I just happen to listen to. I'm sure my list isn't comprehensive, but there is a diverse range of equipment. For NONE of this to stand out in any meaningful way to me, I am of course suspicious that there is any more than just perceived differences between amplifiers. Surely something in this lineup should be considered a good bit better than the others for nothing to sound noticeably different than anything else.
As a sidenote, how exactly does something like the Integra or Denon end up on the same performance scale as something like a Sansui 5050? Both the Integra and Denon are considerably more well built, with more robust power supplies and heatsinks.
Have you spent a week listening to each of those? If so you have been a very busy chap. If not then you aren't really in a good position to say they all sound the same.
Steve
I have been listening to a pair of speakerlab das 7 speakers connected to a technics sa 550.
I have a heathkit ap 1800 preamp and i just bought a haffler p 500 amp.
I have not tried the haffler yet on my speakers.
Will it sound better than the sa 550 or did i waste my money ?
Steve
I've spent a lot of time listening to:
Denon AVR-4802
Sony DA3000 ES
Integra DTR 9.9
Marantz 2215b
H/K PM655
Marantz 170 DC
I do not own all of the models I listed anymore but I have heard them and usually I do a listening test with everything I have at some point.
It'll sound different, better maybe, maybe not.
I couldn't disagree with the OP more. At one time I had 3 amps to choose from in my system: Rotel RA 1412, Bryston 14B SST, and a Parasound HCA 2200II. Every one was different. The Bryston was the best, with deep base and clear highs. The Rotel was nice, but tubby and did not have the definition of the Bryston. The Parasound was good, but lacked a well-defined soundstage, and lacked a bit of upper-range refinement.
I was using the Bryston as my main for 2 years then happened upon a Luxman M 05. I didn't ever think it would cut it compared to the Bryston. No contest. The Luxman was robust in the bottom end, but had a midrange liquidity and top end detail the Bryston could not match. Moreover, soundstaging was much more deep and wide. The biggest difference, actually, was the Luxman over the Bryston, and neither is a slouch.
Not to sound insulting, but good speakers bring out the differences more than "average" ones. The midrange and highs on my speakers are very good, and even subtle differences are noticed, but with each system it is going to vary.
Note however in the comparisions everything else was standardized; same sources, speakers, positioning, room etc..... so the comparision was fair.
Every variable that changes between tests makes the results less valid. You don't come right out and say it, but everything you have said leads me to suspect that there were a lot of variables differing while you were reaching your conclusions.
markdi,
if that hafler is the dh500 it is a brute. it will take hold of your speakers by the balls and force out ANY bass they are capable of and likely more than you thought they were capable of.
another amp that did not sound like all others was the p202 which had dynamic response that revealed that the orchestra swells up in loudness just as in life. most amps (especially receivers) just get louder.
my friend has tow amps, an EAR 890 Power Amp tubed amp and a odyssey stratos SS amp and they are quite different in sound. the EAR sounding more organic and the stratos delivering more of the bottom end slam and punch. both are great amps and that's why my friend couldn't bring himself to part with either.
Differences would be easily measurable at the speaker output.
Average room is so bad for SQ that the difference between amps of similar type will insignificant.
Choose on features (which some may consider design flaws ;)) you desire and ability to reliably output a speaker level signal to your speakers to output sounds at your desired max SPL (because the oft touted watts output is meaningless without knowing what frequency ranges its generated at, what THD, what speaker load etc).
This sort of thread usually questions the truth of some broad generalization, and generalizations don't serve us well in this hobby. Start with something tough to argue with like, "identical signals sound identical."
Now you work your way back through just power amps and see how well they manage to preserve the signal. With the right measurements you'll probably find a huge number of amps in some statistical mid-ground. Good or very good, but with measurable flaws on real loads (speakers) due to economics, skill of the designer or conscious intent. IMO, most of those amps will sound similar and I probably couldn't tell the difference in a blind test.
At one end of the bell curve you'll find amps that sound significantly different. Usually, when an amp sounds significantly different, there's something wrong with it. RF problems, aging parts, stability or response. The difference between good and great is small, so when you hear more than a small difference, that should be a warning sign. Either it needs service or the designer decided to build a musical instrument rather than a reproducer. There's a case to be made for that, but not by me.
At the other end of the bell curve you'll find amps are are close to perfection. What goes in is what comes out, and this is true regardless of the load. Those amps won't sound a lot different than the middle of the curve, but those with difficult speakers or particularly golden ears might pick them out. Or not. In a blind test I doubt I could.
Now you have to work your way back through buffers, tone amps, RIAA preamps, CD circuits and tuner circuits, looking for differences. Taken as a whole, I've no doubt that systems sound different. What makes the hobby go 'round is that almost nobody has the ability (or time and $$) to really sort out what's what and get to the root cause behind what's being heard.
Every time I've been totally convinced that two different amps sounded different (in spite of similar response, distortion, etc.) there's been some outside factor involved. Making the comparison fair (matched and blind), the differences invariably evaporated.
Identical signals sound identical. If you hear differences, compare the signals. If the signals are extremely close to identical, the listening test is probably flawed. If they're not, fix it!
I think that different amps interact differently with a given speaker in a given room primarily due to how the dynamic loading affects them, and the FB loop 'hearing" the speaker and the room thru the speaker. A well-sorted-out amp should sound pretty consistent under differing circumstances tho' that might not give the best sounding amp under the best cdx for a given amp. A "perfect" amp can therefore sound something far less for reasons that confound measurements tho' good measurement figures are a good start to getting an amp sorted out for good sound.
:thmbsp: Very well said!
I skim-read parts of this thread, so I apologize if I missed it, but I didn't catch any mention of the Carver Challenge. Years ago, Bob Carver claimed he could imitate the sound of any tube amp, using solid state. Two magazines took him up on it. I think the amps he had to imitate were a Conrad Johnson and a Mark Levinson, but I might be wrong.
He took samples of each, and measured every variable he reasonably could, and designed circuits that should match. He then took their outputs and, inverting one and feeding in the same signals, worked on them until they perfectly cancelled each other. That is, with both amps cranking, there was no sound output.
In blind testing, no one could tell the difference between the tube amps and the solid state Carver amps.
While superficially one could claim "See? All amps sound alike!", in fact, the two amps were picked for different sound, and everyone concerned (except Carver) were shocked that he could match the amp output sounds so effectively.
Another thing worth mentioning is that yes, different speakers can sound quite different, but this also means that different amps will sound different with the same speakers. For example, I might have two amps that are indistinguishable if played through efficient horn speakers. If I connect very demanding "amp killer" speakers (the same speakers) to each of the amps, though, they may sound very different, if one of the amps is capable of delivering the current asked for, and the other isn't. On the one hand, you can claim this is a difference in speakers, but in fact it is also a difference in the performance AND sound of the amps (when played through the demanding speakers).
With a revealing set of speakers (such as full-range speakers using electrostatics, ribbons, AMTs, EMITs etc... on the high end), there is no question that while SOME amps may sound the same, others will NOT. Anyone with ears and listening experience on such gear will verify this.
That said, with many (less-demanding or less-revealing) speakers, MANY power amps will essentially sound the same. If you are looking to upgrade the sound of your system, get a decent power amp and focus your efforts elsewhere. The transducers at the end (cartridge/TT and speakers) will have a bigger impact, then the preamp (which DEFINITELY impacts sound), and last of all, cables and power amp. But if you start with demanding and revealing speakers (like big early Infinities), then make sure you get a good, high-current-capable power amp, too, because at that level EVERYTHING makes a difference. Maybe even your power cable (if it is insufficient in gauge or has micro-arcing at the plug, or is unshielded in a noisy EMF environment).
I'm on the other side of the fence...
I can 'easily hear' the different sounds of different amps. And quite honestly in my older age, my ears aren't as good as they used to be but it's still very apparent. Different amps sound differently. Sometimes...drastically different. Maybe it's got a lot to do with the 'feeling' too. Of the sound being produced.
I mean, every model amp, from every company, I've ever heard has it's inherent factory signature designed transformer/circuits sound. Flavor. The signature flavor. Which is always there. If it wasn't, I mean, why else chose one brand, and model, over the other. ??? It would all sound 'generic'. right.
Anyway...
When in doubt...get a Sansui! :thmbsp:
Sansuis just 'sound' right. :) No fighting it. It just does. Just turn on the Sansui, kick back and enjoy. Have fun!
Problem solved. :D
And that's what it's all about...right! Not thinking about the darn equipment all the time, or this or that, and just stop thinking and enjoy the music. The music is what it's all about. The equipment is there to play the music - the music isn't there to play the equipment. That would be totally backwards. But I know...what fun would it be 'just listening to the music'? Audiophiles love their equipment.
Once I turn on my stereo, I don't think about the equipment hardly at all. Maybe only in passing in thinking about how amazingly great this Sansui sounds! :)
That's my take on it.
Different amps have very different sounds.
Status
