Amplifiers all sound the same
Status
Not open for further replies.
sorry conrad,
the differences can be easily demonstrated with the same material through the different amps. this time its obvious that higher quality equipment allows more detail through just as finer lenses do the same for the images they capture.
once you get the taste of exquisite inner detail revealed with audio research electronics and magneplanar loudspeakers, the search will be on. i had to be patient as i was raising a family so purchases had to be very carefully weighed.
still, i wish my income was at the level that i could afford MBL 101s and the appropriate electronics and source components to complement them.
http://www.stereophile.com/floorloudspeakers/1004mbl/
breaking things down to the lowest common denominator is a bit more difficult at this level. finding those little pieces of frosting on lower priced equipment will show you that HIGH END doesn't always mean high priced.
try getting some magneplanar MMGs and a tubed preamp and an adcom power amp of about 200wpc (can be had for affordable pricing used). then try going to a tubed amp.
IIRC, the Carver challenge initially met it's goal tho' further listening seemed to separate the subject amp from the target amp. That's where things got complicated for the participants.
sorry conrad,
Nothing to be sorry about. You've described equipment that, as a system, should sound different. I've no doubt whatsoever that if the signals were compared with something else, the differences would be obvious. I could say some things concerning specific pieces of equipment, but that comes down to preference and mine is almost certainly different.
On the Carver challenge, remember that one can also compare input to output of an amp to an extremely high level of precision. It doesn't have to be between some reference amp and target amp. IMO, when the output signal (with real speakers) matches the input signal, the amp has achieved truth. Identical signals sound identical and every single amp that meets that criteria will sound identical.
Just to leave something to claw at, very few amps get the residual signal as low as you might like. Doing an ultra high accuracy design isn't that easy. Fortunately it's probably not necessary. Even moderately good accuracy is probably beyond my ability to resolve if compared to perfection.
It just means the amps are all good and they are all doing their job. Their job is to linearly amplify the input signal. If there were differences among the sound of the amps it would mean they were not doing their job well.
Interesting thoughts especially in these past few posts. So as a general opinion, do you guys think a pair of Wharfedale Diamond 10.1 speakers are a quality enough speaker for difference in amplifiers to be heard? I know those are among the favorite budget speakers right now, and I'm wondering if they're able to reveal differences in amplifiers.
To add on, would my B&W 602 S3's also be capable of this? They are my nicest mainstream speakers, so if they aren't then I don't really have anything which would benefit from this supposed difference in "greater" amplification. I'm certain price shouldn't dictate sound quality, but it is occasionally helpful in determining what sounds good and doesn't on some appreciable level. Then again, HPM-100's go for a decent chunk of money and in my experience did not sound that great. My Interlude speakers sell for a good bit less, but subjectively sound a lot better and have better imaging and soundstage than the HPM-100's.
I just remembered one other time I might have heard a difference in amplifiers. I had a pair of Celestion bookshelf speakers (Ditton, forget the model - had two 6.5" woofers and a tweeter behind a metal grille) and I tried hooking them up to a thin Yamaha amplifier from the '80s, I think it was 30-50 watts a channel. Sounded incredibly flat and plain. I switched out the Yamaha amplifier for one of the better end Sony receivers from the '90s which was still a mainstream model but had dual sub outs, and so on. The Sony made the Celestion speakers sound more pleasant and colored, where the Yamaha amplifier sounded too plain. It seemed there was a little more "oomph". I think the Sony was rated at 80-100 watts a channel, but I was not comparing it based on volume at all - at similar volume levels the Sony sounded better.
From my last example then, what I think happened was I used a neutral sounding speaker with a neutral sounding amplifier which resulted in an incredibly flat sound. Realistically, some amount of coloration is desirable so putting in the Sony receiver added some color to alter the sound of the Celestion speakers.
That is literally the only other time I can recall hearing an audible difference, now is that because the Celestion speakers were that good or is it something else I'm neglecting to consider? Why would those Celestion bookshelf speakers be more sensitive to amplifier differences and the Crescendo speakers which have more drivers and an EMIT tweeter be less sensitive? I would think it should be the other way around. It's experiences like those of the Celestions that make me think it's possible amplifiers sound different, but I'm just curious as to why it's not more pronounced more often.
EDIT: Found a picture that made me remember them, the Celestions were Ditton 200 speakers. Looked like this, I quite liked them but had to sell as they were too big.
Here's an opinion- if you don't like it I've got different ones. :yes:
Flat perfect low distortion response is easy to describe and measure. Engineers are comfortable with it. It often doesn't sound that great, especially if applied to speakers to be used in a real room.
So, the challenge for manufacturers is to build equipment that meets the traditional goals found on spec sheets, lest they not sell anything, but tweak the transfer just enough to have a slight sonic advantage. Tube equipment has an automatic advantage because nobody expects it to produce numbers like ss equipment.
Things like the popular Marantz 2230 and Sansui 2000x are quite flawed in an absolute technical sense, but my guess is people like the units specifically because of those flaws.
The Doug Self "blameless" power amp designs are near perfect on paper, but you notice they haven't taken over the entire market.
Now here's a question. Let's say you had a piece of equipment you thought sounded better than anything you ever heard. Then you discovered it had extremely high 3rd harmonic distortion. Would that knowledge change your perception of it? Would you still enjoy it?
To add on, would my B&W 602 S3's also be capable of this?......
Yes, either the Wharfedale Diamond 10.1 or B&W 602 S3 speakers are easily quality enough speakers for difference in amplifiers to be heard. Absolutely, no doubt. The system where I rotate amps and sometimes compare them has B&W V201's, near BOTL (but pretty nice sounding) bookshelf speakers.
Just use amps/receivers that should, on paper, have a large difference to make it that much easier to start picking out differences. Don't compare 40 year old, unrestored vintage amps. Do compare a fairly new (or a restored) quality amp to a piece of BPC. Just to get things started and give your confidence a chance to move in the right direction.
Don't expect a miracle in just one sitting, especially with added pressure you seem to be putting on yourself. Set aside a time when you can be relaxed and have no distractions. Listen to musical passage that you are familiar with and that you enjoy. Listen repeatedly, trying to be aware of every nuance of every instrument. Then change amps.
Also, don't expect differences between amps to be as apparent as differences between speakers.
a pair of MMGs and an adcom 5400 would not be costly. any good little preamp will suffice to start but a hunt for an affordable tubed preamp such as a Jolida or bottlehead would be a nice step up after a while. if a receiver were substituted for the adcom, the difference would be immediately noticeable.
even good sounding receivers like the sherwood s7900 had distinct limitations. it was entirely unable to drive electrostats like the old but great janszen 412HPs. when i went from the sherwood (not driving electrostats at home) to separate components the diff was VERY clear.
I wish those on both sides would quit trying to convince the other, it's a fool's errand. Just enjoy what you have.
its just that some that state there are no differences either are not aware it can be so or use it as a reason to stand pat with low fi electronics.
it's provable that there are significant diffs.
One perfect amplifier will sound the same as another perfect amplifier. Perfect amplifiers (or anything else, except for me :stupid:, of course) do not exist outside theory.
Recently I made some new purchases (yes, you can buy gear and don't have to a thrift store or search craigslist). I put the new pieces through their paces and also used it as an opportunity to check out some other gear (mostly amps and preamps) that has been sitting idle for a while.
Pleased with the performance of my new pre, I cycled all my amps through the chain: PC/J. River Media Center 19 --> VLINK 192 --> Sherbourne PT-7030 --> AMP --> JBL XPL-200A. Better, more esoteric stuff out there? Absolutely, but this is still a very good and also revealing system. I heard differences with every amp, some of them subtle, some not so subtle. Though the age of some of the amps goes back to late 70's early 80's all are in good service, and all sounded great, but different.
In this system here is my take:
Carver TFM-15cb/6cb: very easy to listen to and accurate, nothing missing.
Emotiva XPA-5: accurate, good sound stage
Yamaha M2: accurate, great woofer control, good soundstage
Yamaha B-2: accurate, great three dimensional soundstage and in color (no other way to express the difference)
The B-2 hands down sounds better to me than the others. The M2 and XPA-5 were tied, each having its own advantage, with the Carver amps coming in fourth. A different system might (likely would) have very different results. I'm also confident that I could tell them apart in an ABX setting with familiar music.
IME, any competently engineered amp designed for transparency that measures well, is not driven to clipping, is stable in to the load, and is level matched will sound like any other. To my knowledge, in proper double-blind testing this has never been disproven.
A lot of people don't like transparent though - they like some measure of non-linearity or distortion. Boutique "audiophile" and other non-linear or microphonic coupling caps, etc. are a great way to get there.
If you're peeking, all bets are off. Sometimes I think my system sounds better than other times. It doesn't, it just my mindset while listening.
When I make changes I listen more intently, looking for changes. Look hard enough, and you'll find them as the ear/brain can only focus on a few sounds at a time... it's relatively easy to hear stuff you've never heard before, without changing a thing.
A lot of amps will sound different, with different "signatures". That will also be reflected in measurements, as what goes in isn't what's coming out.
Both sound great,therefore I'd recomend either,but personally I prefer the Pioneer.It's got more depth and isn't so bright/brash sounding as the Technics.
I listen mainly thru headphones that are quite sensitive (Sennheiser HD-580's with 600/650 cable),which makes me wonder if perhaps your speakers and/or speaker cable are to blame.
Which one is supposed to sound "better"? I always thought people didn't much care for the sound of most of the fluoroscan era Pioneer gear. I've always liked Technics gear personally.
I hardly believe my speaker cable is doing anything good or bad to the sound, it's nothing special. I think my normal wire I use is a short run of 14 AWG Monoprice wire (Not the clear oxygen free stuff, the one with the colored wires - easier to ID and looks better IMO). The 12 AWG Blue Jean Cable wire is driving the front 3 speakers in my 5 channel setup and my speakers in my main system. Makes a good contact between the amp and the speakers, which is all wire does.
Could speakers be to blame? I dunno, maybe. Again, I hold these Infinity speakers to a bit of a higher standard than I'd expect anyone else to without having heard them, since I found them to sound better than a pair of Thiel bookshelf speakers. I don't remember what amp I was using, perhaps the H/K integrated or the Kenwood KR-8010.
I feel as though I'll end up buying the Wharfedales because I historically have quite enjoyed British speakers and they look great, along with their positive reviews. I wonder if the Diamond 10.2 speakers would be a noticeable improvement over the 10.1 speakers? I know with some models, moving one model up or down can lose the magic combination. Probably a new pair of Wharfedales and a new subwoofer, something like an HSU VTF-2 or VTF-3 in my main system I imagine could be a sonic upgrade - at a cost of what, $800-ish?
It works great for those who use the gear under the same circumstances - listening to sine waves.
That, and folks typically evaluate them while listening to music.
Because Class B amps suck when reproducing music, especially at low levels.
I find speculations about useless THD specs pretty amusing. :)
*Proper* DBTs typically use ABX boxes which completely invalidate the results through combining the feedback loops of the amps under comparison. You end up comparing BOTH amps to BOTH amps. Ask engineers like Frank Van Alstine who have measured the results.
Similarly, there are those who use equally crippling tests for cable tests. I found a particularly funny one here. Scroll down a bit for the methodology using a Y-adapter. Hint: measure the results and you'll find that the metrics of the cables are combined at both ends. You end up comparing BOTH cables to BOTH cables.
Sorry, bogus science is nothing more than that.
I hear just fine and they all sound the same to me . It's just a fact .
three answers
the first is that all amps as long they are flat and have low distortion will sound the same.classic 'stereo review mag' answer.
the second is that amps have small deviations in their freq resp and even a fraction of a db can be heard,and that is what audiophiles hear.bump up the bass 1/4 db and in the long run the listener will hear a bass happy amp cut 1/3 db in the mid and the amp will sound mellow.this may sound strange but I have eq many songs and have heard big differences between the eq'd and uneq'd song even though the sliders were never more 1db from flat.this is the scientific answer .
the third answer is that there really is some quality that amps have that only very long term listening will reveal.that have nothing to do with freq. resp. or distortion.this is the audiophile answer.
the only thing I can say to you is listen to the amp for months. if you like the sound keep it, but if their is something about the quality of the sound you dont like get rid of it.regardless what the specs say.
If we are talking about driving the amp into saturation then the situation is entirely different. Different amps saturate in different ways. For example, compared to solid-state amps, tube amps are known to produce a more pleasant sounding distortion when overdriven. This is documented.
Status
