Amplifiers all sound the same
Status
Not open for further replies.
Self talks specifically about biasing in your link (I have his book and have built variations on his designs) and says distortion increases when class A can no longer be sustained with class AB biasing.
The topic under discussion is not about Class A or AB. Perhaps you missed reading the first sentence, aka the abstract:
"The distortion produced by a typical solid-state Class-B power amplifier is shown to consist of eight mechanisms, all of which may co- exist and whose distortion products overlap to give a complex result. Methods for isolating each mechanism for study, and minimising its contribution, are given. If the avoidable distortions are designed out, Class-B amplifiers of unusually low distortion (Below 0.0005% at 1kHz, 0.003% at 10 kHz) may be designed as a matter of routine, and without significant extra cost. Such amplifiers define a distortion benchmark, and I have named them "Blameless" amplifiers."
The article is about his Class B amp.
I don't know exactly what sharp line divides class B and class AB, but IMO practical examples of the Self designs would tend more towards the latter.
Class B devices amplify only half the waveform while AB amps only do so at the highest output level. Highly biased AB amps run Class A up to about 10% of their output - or what would represent most of music (if not horribly compressed). Again, the Self design is strictly Class B. Read the abstract again, if not the entire link.
When all else fails, call a respected designer a liar without having measured the results yourself. Is that the "religion" part you mention? :)
Where, exactly, did I call anyone a liar? You gave brief descriptions of two test methods that you felt were not valid due to the test strap implemented, and I agreed with you.
As far as Van Alstine, not knowing him personally or being privy to other posts on other forums, I have what I'd think is a normal amount of skepticism in any claims that aren't independently verified, or that I've been able to read or test myself.
Now that you've provided a link, I see more clearly what was said, and still agree with you that it would be a flawed test if what he's stating is true. I'm not saying it's not true, I'm saying I don't know if it is.
"Probably good enough to prove his point?" Silly me, I thought the point was to compare one cable's performance vs. another - a goal at which he failed miserably. I tested the results for myself and posted them here. You must have a different objective!
From my quick read of the article it looked like his agenda was to show that a difference could be heard. Is that incorrect?
Your test was interesting. I don't know if you measured other factors, but it'd seem that more than just capacitance comes in to play such as inductance and resistance. Granted, the test method he used isn't discrete so the cables could very well sound different on their own. That's not to say having them connected together at the source means they'll sound exactly the same either.
What it does prove conclusively is that the use of faulty assumptions only makes for junk science.
Science doesn't allow for any assumptions. There's no conclusive proof in regards to the topic at hand, as you gave one anecdotal comment from an amp designer with nothing concrete tying it to invalidating every amplifier ABX/DBT test ever performed, or even that they're all performed with ABX boxes, or ABX boxes that exhibit the problem that was being discussed.
As for the interconnect test, I still think the test as outlined could easily support the authors point, which was simply that a difference could be heard. Capacitance is but one factor, so while you've shown that the cables electrical characteristics can be altered by using that test methodology, you haven't proven that alone will make the cables electrically the same across the board.
Likewise, my statements are anecdotal as well.
On the other hand, computer based ABX tests where you compare one digital file vs another are free from such easily debunked assumptions. Here's one I took a while back using a laptop and Shure earbuds that measures your ability to hear distortion. There are a couple of different tests there. First, click "Take Test". Under "Reports", chooses 6" driver and under "Info", Music T. Chapman. At the end of the test, you will see your results graphically. Here are my results:
Post yours!
To what end? It has nothing to do with the topic of this thread, and I obviously have no problem with ABX methodology.
You don't agree with what I said - fine. I've no problem with that. You've posted some intriguing anecdotal information, perhaps someday if I get some time I'll investigate what you've provided further. However, it is by no means conclusive proof of anything, just as nothing I've said is conclusive proof of anything either.
I've read just about every argument on this topic I care to, and have clear pictures of the data, anecdotal evidence, and default claims used by all sides to further their cause, as I'm sure you do as well.
I'm not here to convert anyone to what I think about this topic. The OP asked a question, I provided a view. If the OP wishes to investigate the topic further and draw their own conclusions, great! If not, great! It makes no difference to me.
There's no usefulness to this thread other than to make the statement that all electronics sound the same to the OP which seems to be the one indisputable point in all of this. Beyond that, it's all conjecture. I mean, if someone heard all that gear and it all sounds the same, the most likely conclusion isn't that all the gear performs the same. Because it's certain that it doesn't.
It's the same ol' story, If you spend the money then you are convincing yourself you hear a difference to justify the expenditure. If you dont want to spend the money then you are convincing yourself you DONT hear a difference to talk yourself out of spending the money.
I think making any blanket statements like "all blah blah blah sound the same" is a great way prove you have no idea what you are talking about.
That view only works when money is a factor. What explains the differences (or lack thereof) when money isn't a concern?
I was looking at buying a more high end amplifier to replace my Denon AVR-4802 that I've used happily for several years, but I think I was doing it more so I could feel confident that it was definitely "high end" and there was no way I wasn't getting the best sound out if I had an expensive power amp instead.
My experience is that it is often harder than you might think to know whether or not you hear a small difference. And it is neither so simple as just "here's what the measurements say" or "just use your ears."
The good news is that those small differences aren't usually critical or decisive to general musical enjoyment.
Otto
Some people aren't very good listeners, and some can't hear differences because of the rest of the components in their systems. The OP's opinion is just that. Numbers and tests will mean nothing.
"So based on another thread here, I shared a belief I am starting to hold strongly - that amplifiers ***pretty much*** all sound the same. I have tried very hard to hear differences, but honestly I think I'm just trying to convince myself."
Either they do, or don't sound the same.
What explains the difference? I don't know , I'm no amplifier designer, but that doesn't mean there is no difference. Just because I cant explain why two amplifiers sound different doesn't mean I cant hear the difference.
hey I am sure lots of amplifiers sound similar but not ALL amplifiers sound the same. My problem is with the blanket statement.
Your response to what he described as measured:
"Just because there are some examples of incorrectly performed testing..."
Yes. His *agenda* is to describe how he uses valid testing in his development, not parlor tricks. Did you read how he compares one channel to another?
Absolutely. One is most certainly not comparing cable A vs. cable B. The test compares Cable A+Cable B vs. Cable A+Cable B.
No $hit?
Precisely why I provided two examples where the use of assumptions - not measurements - invalidates those tests.
It invalidates ALL tests using ABX boxes that necessarily must share grounds or cause gross switching transients. Do you ever switch interconnects on your amp while the gain is set high? Don't know about you, but I never do that. :)
We must have read different articles. His conclusion was to the contrary. I would quote it for you, but the site is now unresponsive. It may have to hit too much since I posted the link.
Huh? What I proved is you are no longer comparing one cable vs another. There is no comparison at all between BOTH cables and BOTH cables. Do you understand that?
It would illustrate why I hear differences and you do not by way of contrast.
I've measured the results for myself confirming observational data and ignored the results from non-scientific parlor tricks.
The point I was trying to make is that cost of gear should not be considered a factor when reading peoples' evaluations of anything. Not everyone is tyrannized (or even affected) by regard for monetary value. And those of us who are land at various places on a continuum.
I guess I mean to say that not everyone is concerned or even aware of what things cost so they wouldn't be convincing themselves of anything based on it.
Only the realities of what it takes to realize the best engineering. You'll note quite a few differences in the Adcom designs by Nelson Pass that are built to a price point vs. what Pass makes himself.
Better quality parts, active and passive alike. Stiffer power supplies. Class A operation.
Nelson Pass does some of the best and most accessibly manageable esoterica extant by reputation, this is not gear I can or would recommend to the average 'phile wanting decent sound at high value for budget like his Adcom amps. As much as I'd like to spend time with a First Watt amp I can do nicely with my Iverson Eagle 2 as a very good stop-off point that can drive some pretty demanding loads and still be sonically excellent. I like the GFA-535 enuff to recommend them, pass them around, and keep one around as a back-up for the Eagle and the Belles/OCM Soloist 200 FET amp.
My response to what you paraphrased he said, as you hadn't provided a link to the thread you were referencing at that time.
My read is he was referencing test straps that caused the issue he was citing, and I didn't disagree. It doesn't prove that every ABX/DBT test ever performed was done so incorrectly, and stating such isn't calling anyone a liar.
I was talking about the ESP cable test, not Van Alstine.
If what you're proposing is truly A+B and B+A, then I perceive you as saying both cables would sound the same. I agree the characteristic of both cables are changed, but there's no evidence that they are now the same.
If you want to provide inductance, resistance, and impedance along with measurements of noise, reflections, etc. and show those as the same from either cable, then I'll agree with you.
Nice.
When I see some actual evidence of this instead of hand waving, I'll agree with you. Right now I'm undecided.
The site doesn't respond for me either. For the third time, what I read was he was only providing a method to show that a difference could be heard between two cables of differing electrical characteristics.
I didn't read the entire article, just the part you mentioned. Maybe I read it wrong. I don't see how it matters anyway as I've already agreed (from the beginning) that the method used is no good for a true comparison.
EDIT - the page came up - I read it wrong. Still don't see how it matters as we're agreeing the test method is bad.
I understand what you're saying. Response above.
I didn't say I don't hear a difference. I generalized, but did give parameters. I've listened to amps where I hear differences, and I've listened to amps where I don't.
Since you've such respect for science and hatred for parlor tricks, you must concede that I've no choice but to take what you say as anecdotal unless you provide details of your test methods and actual measurements of what you tested.
While this has given me some things to think about and investigate, I don't see that it's doing the OP much good at this point, and frankly I'm a bit tired of being a target for your personal attacks, so I'll bow out now.
Nice.
Don't feed the Trolls
So there is no current flow at cross-over here? Wouldn't that be unlistenable at normal domestic levels at/below the "first watt"?
Agreed about their value.
Weren't we talking about whether or not ALL amps sound the same?
Urgh, when posts get broken up into 1 sentence quotes and responses my head begins to hurt.
And I don't think all amps sound the same, the ones I've heard have always sound quite different. If the OP doesn't hear a difference there's not much to say... Pick one that looks the nicest I guess.
That is why class B amps are not commonly used with audio unless you include pro amps. Back in the day, I once had an AR amplifier based upon a Julian Hirsch review which used a Class B output stage. Sounded pretty decent driving Advents at high levels, but resolution fell apart at low levels. That is the Achille's Heel of such designs. Which is also why virtually all preamps and other line stage devices run Class A.
Even took it to a McIntosh clinic once and Dave O'Brien tested it and handed me the fancy THD plot which looked great!
Status
