So I got my new copy of Art Blakey and the Jazz Messengers' Moanin' LP in the mail this morning. Dropped it on my trusty, old (hey, I bought it in the spring of 1981) Philips AF-829, and wow!!! Sounds great!
Five minutes into the first track, and I get nailed with that 60 Hz tone.... No problem. I'll just tweak the grounding wire like I've been doing for decades. Great.
Two minutes later, the 60 Hz tone is back. I tapped the grounding wire again, and all is well.
Only now, that's happening about every two minutes. Before it might be every three or four months so it never really bothered me all that much.
Mind you, nothing has changed about the turntable. I haven't re-positioned it or anything in months, but now I'm afraid that this grounding wire thing is getting out of hand.
I'm thinking that it's time to replace the interconnects and grounding wire, or at least the grounding wire.
Only, well, I've never soldered anything before and this looks like a particularly delicate bit of soldering that needs to be done seeing as the interconnects and the grounding wire are on this tiny circuit board. Seriously, it's like a quarter inch by a quarter inch, and there's just a tiny bit of solder holding the turntable ends of the wires to the circuit board (there's a double ess thing that the wires pass through on their way out of the plinth, and that prevents those soldered joints from feeling any stress).
So now I figure it'd be best for me to try and fix this by digging up an electronics repair place in SE Michigan. I'm in Troy, so if anyone can attest to the quality or ability of the work done by that place down on 14 Mile Road, just east of John R, I figure that'd be the place to take it.
Unless you have a better idea. I don't mind traveling as far as Ann Arbor (give or take 60 miles) if you can recommend someone else (someone better?).
I called the guys at Audio Dimensions and they suspect that the fault lies in the grounding strap too. Just wondering if you guys can shed a little light on this for me.
Thanks.
Thanks.
