When a PCB is assembled, they use a method called "wave, or flow, soldering. That turns out a very pretty solder joint which is difficult, if not impossible to recreate when servicing the equipment. They employed this stuff in a facility I worked at in the mid 70's.
When repairing the boards, one runs the risk of destroying or lifting the runs with too much heat. If it works, be happy.
https://www.pcbway.com/blog/Engineering_Technical/Wave_Flow_Soldering_Process.html
