Mahan Safaei
I have been trying to figure this out reading the different threads but haven't had much luck:
I have an Onkyo TX-860 receiver which has a minimum 4 Ohm impedance.
Now this amp allows for 2 sets of speakers to be connected to it and has a selector, Speakers A and Speakers B.
The question is, if I connect a 4 Ohm set to Speaker A outputs, and an 8 Ohm set to speaker B outputs, and have both switches enabled on the receiver when listening to music, will I be exceeding the receiver's suggested impedance?
What's confusing is that I don't know if the A and B speakers are paralleled into the same amp inside the receiver, or in series, or if they use separate amps altogether?
Thank you in advance!
-Mahan
-Mahan
