The 1010 is NOT a BEGINNER LEVEL unit to learn on. It's more in the High Intermediate Level to ADVANDED level. If you want to tackle it, you need to do some HEAVY READING 1st, and learn the terminology. Also comprehend what we are asking with regard to parts location. We ask for board NUMBERS for a GOOD REASON. They are individually numbered with INDENTIFIABLE Part numbers. And NO TWO ARE ALIKE. Makes it easier when you say "the transistor on the board next to the sky blue capacitor, next to pin #5." If you say, on board #, the 2sa725(Qx....x=number of the transistor from the manual/schematic) next to pin #5, it's easier to trackdown, troubleshoot, and diagnose. Look at how most of us write out the parts lists, voltage lists, etc. The way we write them out, (including part Numbers, x-ref's, Voltages including polarity, and type of voltage (-13VDC or +27VDC or 65VAC) helps everyone, again.
So lets get started.
The "motorboating"(put-put-put) and the crackles, pops, etc(Rice Krispies) are definately a symptom of the breakdown of the 2sc1451 transistors, and also 2sa726 and 2sa725's. Plus probably some Cold solder joints, marginal caps, etc. thru out the unit, but the 2sc1451 and 2sa726/725 are the MAIN SUSPECTS.
These are, as a couple on here have mentioned already, are KNOWN troubleprone transistors and
MUST BE REPLACED PRE-EMPTIVELY. The chances of them being bad is 99.99999999994%, and it's a "WHEN they go bad, not an "IF" they go bad. They are #'s 1, 2, & 3 on Mark the FIXER's TOP 10 WANTED LIST for 1970's PIONEER EQUIPMENT.
REPLACE THEM!
Generally the latest 1010 list is incorporated in this thread as a link. Go thru the list and VERIFY VISUALLY, Each part on yours.
PIONEER did make UN-ANNOUNCED Line Changes that DID NOT make the manuals.
Once verified
POST THE PARTS LIST, and it will be vetted for "Obsolete, NLA, or uprated parts". DO NOT ORDER anything until the parts list has been Visually verified BY YOU, and and vetted by one of us.
HEAVY READING LIST.. ..(Break out your Library card!)
BOOKMARK THESE
1.)
http://www.audiokarma.org/forums/showthread.php?t=249745 (PIONEER TUNING FORK SERIES. A MUST for anyone working on PIONEER Equipment)
2.) PIONEER RECAP STICKY.
http://www.audiokarma.org/forums/showthread.php?t=457663
3.)
BiPolar Junction Transistor Testing Pay particular attention to POST #11.
http://www.audiokarma.org/forums/showthread.php?t=43186
4.) DIY Forum repair & restoration reference threads
http://www.audiokarma.org/forums/showthread.php?t=426532
5.) Another from ECHOWARS....
"So You Want To Repair Audio gear, Eh? Here's the tools you need..."
http://www.audiokarma.org/forums/showthread.php?t=333423
6.)Sx1010 BOM List (
This is the list for the 1010 in Item #2. )
http://www.audiokarma.org/forums/showthread.php?t=514144
VERIFY this against your unit 1st then post the list on this thread for VETTING. DO NOT ORDER until vetted. (This helps everyone. You get the latest list, and we can take the latest list and change Item #2 above, so future users will have a current version. )
7.)Pioneer SX-1010, 939, 838, et.al., Relay Replacement
http://www.audiokarma.org/forums/showpost.php?p=6759577&postcount=30
