Another Restoration, 9090 non DB receiver
And now tone control potentiometers
As I already written, it is not so good to use contact cleaner without open those potentiometers, because those potentiometers has some grease inside of them, and that contact cleaner can make things worse if that grease finally arrived at potentiometers contacts
Finally what I have cleaned until now…
I wish to show you something… It was one thing which can make me a big trouble during dismounting switches from boards, please take a look at the next picture
You see that bended switch pin? That pin was bent in the factory to fix that switch to the board before soldering, and if you didn’t remove all solder material from that point, you will damage solder point during removing that switch from board!
Another switches need to be cleaned…
And speakers selector…
And cleaned…
At this stage of cleaning, the receiver looked like on that picture
And there you can see tone control finished…
And finished the Protection Board with Speakers Selector
And how it was (missing Speakers Selector)
And now, how I installed a new main capacitors… The old ones was 6800uF 71V and with diameter 40 mm, I decided to install BHC Slit-foil capacitor 10.000uF 80V, but those new capacitors are 35 mm in diameter, so I have to adapt clamps to accept those new capacitors
On the next picture is wiring of old capacitors…
For connection capacitors to the Ground, I used that cable (from one coaxial cable)
And finally, now it looks like on the next pictures
Wow!
Fantastic job by the looks of the work you have done.
I am getting my 9090 done now at a local accredited shop.
I can only hope that their techs do even close to the type of detail you are doing.
Thanks for posting all the pictures .
Great Job!
And now, very specific part… The Front End of tuner section... The first thing I had to do was to desolder the connecting cables
… and here it is…
… on the next picture you can see one detail, mechanism for rotation of capacitor, and you should be very careful with that…
… now, it is out… and I can clean with deoxid contacts to the ground, wich is very important for proper work of that part
… installed back…
Now… changing back-lighting of the power meters, very hard to do…
The old bulb…
New bulbs…
And checking…
… driver board…
After I resoldered all solder points…
What I have changed on the driver board…
Some details…
Just one step until end… Tuner Power Supply Board
There, I changed an original heat sink with better black aluminum heat sink, because that TO220 transistor generate heat, and I think that new one is much better than old…. But I had to adapt it to holes for fixing heat sink to the board…
Finally it looks like on picture below…
Almost finished… installed back power TO3 transistors…
Hi unbelievable job done on that from start to finish!! How do I get the privilege to be in line or be number 4 or 5 for you to work on my one owner 9090. She's in pristein cosmedicaly and never been touch by anyone or taking apart I mean. All switches are dirty tuner doesn't tune in like it use to. But it plays and works and all lights light up. I just put in away until I can find the right person to go through it . and if I could be so fortunate to have a complete Restoration on this prized Reciver like one you just did. It'd be like the closest thing to buying a bran new one just out of the factory today. I'm just afraid if I keep using it a cap will explode or somthing like that . there's a lot years on them parts. Where do we find tech's that will do this kind of job and of coarse be compensate fairly for this kind of quality repair / total restore. I know I would pay the right guy to do this kind of work that he's done here. Hey if you would consider working on a sansui 9090 that's in alot cleaner shape then this one was and restore mine shoot me a PM and I'll get right back ta ya. And ya if I'd had to waite 6 months for this kind of work to be done I would be thrilled. Heck even longer who doesn't want there gear worked on by a true pro!! You waite as long as it takes for him to get to your gear. Because in thee end it's So Worth it!! Please let me know about a restore thanks!!
The grand Wizard of restoration has worked his magic. Any thoughts on the sound ?
...and thanks for sharing, your descriptions are almost as detailed as your work. It all takes time.
What is amazing is the time spent in control cleaning. They are a royal pain to rebuild, let alone all the tiny parts and springs in each one that love to run away and hide when released from their housings. It takes me about 30 minutes to deep clean just one IF no parts try to evade me on reassembly. Always a highlight to read your threads Kale, awaiting your next adventure :)
-Lee
