Hey all. I am in the process of hooking up a stereo in my garage. I am, also, running new electric service and electrical drops throughout my garage. Anyway, I have a couple questions.
First, I built shelves and placed the speakers I am going to use in two corners of the garage. They are not each the same distance from where I placed the stereo. One speaker is about 50 ft away from the stereo and the other speaker is about 24 foot away.
My first question is do I have to (need to) run the same length speaker wire to each speaker? If so, do I just coil up the excess wire to the shorter run behind the speaker?
My next question is about running the wire. As I said I'm running new electric service. I'm doing it the "traditional" way and running the perimeter of the garage up high and then "dropping" down multiple new outlets. My question is whether I can run the new speaker wire ON THE OUTSIDE of the conduit without getting interference into the speaker wires? I was thinking about just running it along the outside of the conduit and then just using cable ties to secure it in order to make it neat.
I probably going to be using 14 gauge wire. The speakers I'm using are 8-ohm Realistic Optimus 1Bs. I'm following the chart on the Roger Russel website which states I can use 14 gauge wire for runs up to 80 feet ( http://www.roger-russell.com/wire/wire.htm ). Does anyone disagree with that? I haven't bought the wire, yet. I'm not sure whether I'm going to buy actual speaker wire or just some 14 gauge zip cord. Any thoughts? I know this subject has been beaten to death in many, many previous threads.
Thanks
Thanks
