sachu888
Spare the tigers, kill me
I like it! You have MUCH more room in that box than mine...glad you got the humm problem solved.
Thanks Vincei,
Regards,
Sachin
Good advice here. Another helpful thing that I always use is a magnifying glass to closely inspect each joint for good coverage, no holes or excess solder (perhaps leading to a solder bridge). I only solder one or two components to the board at a time and inspect each joint under the magnifier as soon as I make it. Triple-check each component and its position before applying solder and touch up any joint that looks potentially iffy before moving on to the next. This can save you a lot of headache and wasted time later on. A good solder joint will have a nice shiny silvery sheen to it.
It takes a little practice, but patience and careful work will get you places. The only way to learn is by doing, so dive in and have fun.
Very handsome combination.
At this point if I were you I would call your preamp/turntable combo complete and if I got the urge to upgrade I would look to other parts of the system. That is a nice setup.
Shelly_D
Very, very nice, Sachin! Looks great and I'm sure it sounds great too.
Hi,
My MIcro Seiki MB-14 arrived today, which I bought it from an AK member.I have paired CNC with it.I am using shure M55e cart.I have not heard many high end phonostages but CNC sounds definitely better from most of the phono pres I heard.
REgards,
Sachin
There ya go. Nice setup. What power amp/speaker combo are are you driving that with. Oh and nice coffee cup there. Fiat is coming to the USA again.
Cheers,
Bob
Stupid question(s) time again:
1) Does the wire running to/from the ground terminal on the case have to go/connect to the +/- battery wires that go to ground on the board or can it just be (say with an o-ring terminal) be screwed onto one of the four corners where the board mounts to the case?
2) Do I have this correct that one battery + and one battery - connect together and run to the ground on the PCB board?
Hi,
For grounding and battery connection take ref from the pic posted by Shelly_d in post#317. It helped me too.
Regards,
Sachin
3) For the LED. Do I have to wire inline (splice the wire) for the wire running to the PCB (noting polarity), or can I just wire to the switch terminal (PCB side)? Would it go - LED to resistor to PCB - terminal on the switch (then + to PCB + terminal on the switch)?
4) For RCA jacks/wiring.... if I have a small portion of copper showing, do I need heatshrink to the RCA jack connection or tin the rest of the wire or is it OK to leave alone? If I do nothing, will it pick up on noise? It's maybe 2-3 mm at the most.
Look carefully and you will see that chassis ground, L&R channel shields and the common point between the two batteries are all tied together.
Has anyone tried listening with different resistive loadings? Am curious to know how much difference can be perceived when you switch the switches.
I haven't got my RCA jacks attached yet so haven't even applied power.
G'day mate, actually there is a point of confusion here as so-called 'less loading' (in terms of a lower number eg '33 k'), actually 'increases' the loading on the cartridge.
33k is actually a heavier resistive load than 47 k, for example. Increasing the loading causes the upper treble to roll off.
It's an inverse sort of situation. Regards, Felix aka catman.
If you're talking about the PCB, I'm a bit new to all this. It's all pretty Greek to me. I'm slowly grasping what's going on but always appreciate pictorial and verbose (and dumbed down) feedback.
