i finally had some time to put into the amp again. its 4am here, so ill make it short - pictures later.
i've finished recapping the power and the amp board - so only the biggest board in the back is left (did some obvious bad solder points on that, otherwise untouched).
since i don't think it'll be easy for me to take the last board out (big switches), and i can reach most stuff inside the frame, i decided i could put the smaller boards back in for a quick test.
i've had some dead and leaked caps on the amp board, a corroded trace, which i cleaned and sealed again - it measured functional, but i dont have the knownledge and equipment to do in depth testing. i also reapplied new thermal paste to the regulators/transistors.
tested with headphones.
good things first:
- the c4 didnt blow up
- the c4 didnt trip fuses
- we restored full volume potential (YAY)
- we dont have weird dropouts
- (found the "ting" sound of the relays
the bad things:
- huuuuge distortion, the song is barely recognizable (over headphone output) ("diodes"? transistors?).
- we still have that weird balance issue going on, where left (? i believe) channel doesnt really have output.
- disabling tone control kills the signal - im not sure whats up with that, i might recheck that board tomorrow.
i've pulled out quite alot bad caps, i wouldnt be surprised if there were another few dead caps on the last board, so i'll proceed with that. aside from, do you have some ideas what to (re)check?
thanks alot in advance!
