D_Canard
Member
I have a new-to-me Dual 1229Q which has quite a number of things wrong with it, mostly minor individually but cumulatively major.
In this thread I will talk about the mysteries of anti skating.
I have read that anti skating is very difficult to set up without a test record and an oscilloscope. And even then an optimum test record setting is probably only a best guess average for real life play using different records at different speeds.
I have neither a test record nor an oscilloscope so enough said here.
I do have my eyes and ears, though, and I can see and hear that there is something very wrong with the anti skating calibration of this 1229Q.
I have the tracking force set at a mechanical-balance-scale-measured 3 grams. (The calibration of the tracking weight dial scale on the tone arm is way off, too--I set if for 3 grams and then use the mechanical balance scale and counterweight to set it accurately to 3 grams.) I use mostly small bodied Stantons (500s) and Pickerings with a variety of different styli for playing 78s, 45s, microgroove LPs, and older LPs that skip on my way too highly compliant modern high-end turntable. 3 grams is a little light for 78s but it works. On my older Dual I used 4.5 grams.
If I set the anti-skating at 3 grams (on relevant scales), auto-start does not work reliably, the tone arm often throwing itself off the record, nor does auto stop-work properly (the tone arm skipping before it reaches the run out grooves or kicking back across the record once the arm starts to lift). At 3 grams of anti-skating, LP play is the least problematic, still problematic, though. 10" microgrooves and 78s are much worse. And 45s are the worst. Also things do not sound all that good with anti skating at 3 grams.
The machine sounds and performs best with the anti skating scale set at 1 to 1.5 grams for the 3 gram tracking force, depending upon whether a conical or elliptical stylus is used. Auto start and stop work. Channels seem more balanced and there is less distortion. So I guess .... things are sort of OK.
But it would be nice to have (both) the anti skating dial scale (and the tracking weight scale) calibrated correctly .... (Tracking weight scale calibration is a topic for another thread.)
The Service Manual says not to mess with the anti skating mechanism under the tone arm. Special tools are required, Dual's test record and Dual's anti skating force meter. Has anyone ever messed with this stuff and come out alive?
I do not have one of the blank anti skating test records (wouldn't mind having one, though). I have read (but do not know for myself) that they are OK if they come with good instructions and the instructions are followed. My possibly ill-informed understanding is that the anti skating force is to be set to the point where the tone arm drifts ever so slowly towards the middle of the record and not so that it remains static in place. But what do I actually know of this? Nothing really.
Thoughts, comments, suggestions, advice?
Is there another explanation for the malfunctioning of auto start/stop other than excessive anti skating force?
