One word....double blind. OK, that's two words, but it sure does weed out the snake oil.:yes:
Sure isn't how I listen to music.
Makes it hard to turn on the stereo system, too.
I have found that long term listening is the best for me. Do whatever changes you need to. Listen for a few days or weeks. Switch back.
Difference = better? Difference = worse? Difference = so slight that it's simply not worth the cost? Difference = zero?
Now you have your answer.
Though I often listen with a double...
Me too. I like the idea of double-blind testing in principle, but I think it is hard to apply to audio.
Speaking of doubles...
Seriously, though:
Some days I have not really been "in the mood" to listen to music. Didn't sound satisfying or whatever - I just could not get into it. Upset? Dissatisfied with my job? Whatever.
Then other days I just could not turn off the stereo! I was wishing that I did not have to work the next day.
The human condition/mind set can be very powerful!
Military dudes ROCK! :guitar::guitar:
I believe the Russians were using tubes in their airplanes while the US had moved on.
However in the event of a nuclear war, tubes would still function (the 'plane will still fly) while US airplanes would be grounded.
But there really is nothing to worry about. Rest assured, that in a nuclear holocaust, your tube HI FI equipment will keep playing!
Where can tube dampers be bought?
Apparantly Marantz decided in the 1980's that vibration control for amplifiers matters:
"The PM-94 and PM-94 Limited differ somewhat very little: gold looks, wooden sideburns, a special compound added to the four feet for better vibration damping, better caps, phono stage componentry and an added top aluminium plate make the PM-94 Limited."
http://www.thevintageknob.org/MARANTZ/PM94/PM94.html
There is a small pic of the feet that shows the white vibration damping material. The feet on my plain 94 doesn't have this stuff.
if you vibrate at the same speed as the amp, would that cancel out the need for damping?
Yea, good luck with that.
The first vibration "experiment" I did was with bubble wrap from a package that someone sent me. Much to my surprise, I heard a tonal difference.
Did you wrap your head or your torso?
