The bulk of TTs once were idler drive, inexpensive lightweight stamped-out plinth-and-platter rim-ringing rumble generators.
Have you ever built an idler drive?
I haven't built one from the ground up, from raw materials; but I have redesigned one from its stock configuration, to that with a new motor and new driveline, and it was an intensive effort that took most of a year to accomplish (in my free time). Its not a job that was easy, nor would it be so cheap.
New bearings for Lencos run from $350.00'ish to $1k.
In mine, my new DC motor ran me around $400 for the motor and controller board (precision 24v DC motor and card). I used the existing platter, bearing, and top plate, and an aluminum Lenco idler wheel in a Presto deck. Details, here: http://www.audiokarma.org/forums/showthread.php?t=380100
That sure doesn't look at all like the AT-60 I had. :lmao: But... no auto spindle? No sale!I do not see what the Big Deal is...They made these Things 50 years Ago, very Nicely...It's only an AC Motor turning a Rubber Wheel on the Inside of a Platter, it ain't Rocket Science...As far as Rumble, all you have to do is Isolate the Arm. Like on this Garrard AT-60. There is No Rumble at All...And, being an Unipivot Arm might Help Too...
That would be retail prices, sometimes with considerable markup. I've investigated having local machine shops produce copies of the Teres bearing and also copies of the TD124 bearings. The Teres copy was quoted at 150.00 each when ordering 20 or more. The TD124 bearing copy was roughly 120.00. They are expensive to buy, they simply aren't that expensive to produce.
I also have a brother who teaches machine shop with access to very nice CNC equipment. If I provided a CAD drawing, I could probably have a finished bearing within a couple of days. Realistically, most people wouldn't have this sort of access, so I didn't mention it.
I think what you are running into with your costs is that you purchased items where I was suggesting a mfg engineering/manufacturing the bits.
What sort of motor did you use? A Maxon EC motor can be had pretty cheaply and building a high quality controller for it could be done for roughly 200-250.00.
Again, it's not that it's necessarily cheap or easy to build for you and I, but the complexity is greatly exaggerated from an engineering standpoint, IMO.
These are complex engineering feats:
8< images
It took a long time, and many tries to develop just the idler arm for the build I did, and it finally got down to measures of .005" between make-or-break for proper contact between the platter and wheel.
I have a reasonable amount of DIY experience and drafting skills. The drafting got me in the ballpark, but was still out in left field until the real trial and error began.
Exactly the kind of thing I had in mind when I said the devil in the details.
I read the entire Lenco Heaven site, took the entire thing apart, cleaned and checked everything, put it into an 80lb plinth, added a spare RB300/Clearaudio Beta S and gave it a whirl.
IMO if anyone thinks that Oracles, VPI's, LP-12's etc are a match for one of these things they have never heard one. I have heard those tables and others like them for 25 years and the GL sounds clearly different and clearly better IMO.
Marc mc
Did you drill a new hole for the RB300 or just used the existing aperture?
I suppose it's all a matter of perspective, it may be easy to very difficult depending on experience and resources. In the grand scheme of things, most experienced engineers that I know wouldn't have a difficult time compared to the things they work on on a day to day basis. There is no doubt that I would run into similar details that you did but I'm also not going to be dedicated full time. A full time week of work would exceed my total free time for a year, so I'd anticipate a project like this would take me over a year, too.
Hrmm...I agree completely. They work on far more complex projects than turntables and in comparison, a turntable would be "easy".
At the risk of hyperbole the Lenco has taught me that there is a very wide margin of error associated with very talented engineers and this seemingly "easy" idea. And that spinning a record perfectly while dealing with the variables that a stylus dragging through a constantly changing groove resistance without smearing the harmonics on a micronic level has proven to be a handful.
Marc mc
