As always, many great advice on D3imlay moderated page :thmbsp:... I am renovating two PL700II gears, export versions - one with quasi and the other with fully comp output. My current focus are PL36 boards. However one can find this kind of message regarding the output transistors matching for PL700II:
"(...) Bob Carver discovered that other amplifiers of the time that he designed the Phase Linear series, used a dual darlington output stage. This configuration had a distortion curve that would rise quickly with an increase in the current in the output transistors. Beta or gain collapse was the cause for this. Bob's triple darlington significantly improved the performance, but you still could not get optimum performance by just replacing the transistors with off the shelf units. To achieve the highest performance requires matching the Beta of both sections of the darlington totem pole. (...) We use state of the art epitaxial power transistors (i.e. MJ15024) and test and match them in the same totem pole configuration as in Phase Linear amplifiers. The upper and lower totem poles are independently characterized for beta at 32 amperes collector current and then burned in for 72 hours. (...)"
Do you agree? I was planning to use off the shelf MJ21196/95 still available at e.g. Mouser. Would I need any specific selection to take into account? Thanks for your comments!
