@Smitty43
Garlic is normally a fall crop that overwinters until harvest, which for me in NC will be around june 1. I plan early, order early, and also plant some of my saved harvest such that I plant a boatload of garlic. This crop is 7 different types totaling 125 in the ground. The pics below were taken 5 minutes before posting, and everything is looking good! So Nov 15 planting ties up a 4' x 6' portion of one of my raised beds until june, then I plant zucchini and yellow scallop squash, until planting again mid November. The issue of planting in the same bed multiple years is open to debate. I have never had a problem.
Here's the deal with spring planting garlic. You don't know what you're getting in those impulse packages? Generally probably a softneck type, rarely a hardneck unless specifically noted on the package. Softneck stuff is what the grocery stores get from California and China and convince us it's garlic! Anyway, spring planting is ok, get it in the ground as soon as you can turn the bed over. If you get the local purchased garlic early enough, place it in the freezer for a few weeks, then plant, however, because of the shorter timeframe you will be working with it may not help. But, typically what you harvest will be smaller heads, but should still be better than the store stuff. Don't buy garlic in the grocery store to plant, because you don't know what you are buying, period! Now, I have seen purple stripe garlic in stores before, which when I see it I buy it, but that is to use now, not plant.
There's a lot to learn about garlic, for example there are about 400+ different garlic strains out there! WOW! I currently plant 7 types, but will probably go back to 5. Some are hotter flavored and lingering, some are mild, some have under-tones of different back tastes....there are no bad garlics from your own garden. The difference is the outstanding flavor that increases your cooking skill, and sure helps with the comments from friends. I do give some of my harvest to friends, maybe 30 or so, but I do keep it close to the vest. Right now some of my stored garlic is getting a touch dry, bot some are just fine. That is where the storage periods come into play.
I know I posted before, and I doubt there is any stock left but you can learn a lot...a lot...from
www.keeneorganics.com which is now the only source I use for garlic stock. They have some choices recommended for our more moderate climate. Years ago I would order from 2-3 different places, but that got carried away...
Check it out and plan ahead. And when I say order early, that means selct and order by May 1, don't dawdle or you may not get what you want.
Grow garlic, I have a blast every year, and my planting board which I made I can plant 100 cloves under an hour!
