Drummerboy2
Well-Known Member
Looking for feedback on what cartridges others are using with the 370H tonearm. Also if there are any tweaks to make it better. I have read using a heavier headshell from Jelco and heavier counterweight to start with.
I've used my Benz Glider, AT33PTG, and stock Denon DL-103/103R on the stock headshell and a Nagaoka headshell. There's no reason to add mass to the arm to run most cartridges IMHO. If you're going to experiment with wood or aluminum bodied Denons, you'll definitely need a heavier counterweight.
jeff
I have two, one unused. I was thinking about upgrading the wiring, but apparently the arms are a real nightmare to rewire.
Oh, the Ammonite base is a real upgrade over the stock Jelco!
I have one of these - an SA-370H, and I've so far run a Grado Blue3, Garratt P77i and AT VM750SH and they've all been fine. I have added some oil to the damping well, which I think helps smooth out any potential mismatches. All I can really say is it seems to work perfectly well in my setup.
I took a peek at those Bases you mention a couple days ago for kicks.
To my eyes. they didn't look much different to me than a stock Jelco Arm Base.
I say this, because these Bases look to have the same "egg shaped hole" the Jelco's have.
With that said, then I don't see how there's a better mounting of the Mounting Shaft of the Arm? Might be some if the tolerances are better, but still.
About all I noted that you might call an upgrade, was a Nylon Tipped Locking Screw, which I'm sure one can source from a Screw Shop, or McMaster-Carr.
I went one better, had one custom made, and to my specs a 1/2" taller than stock due to Platter, no need for Donut spacers required. The hole for the Mounting Shaft is perfectly round with extremely tight tolerances, no egg shaped hole, absolutely no wobble or possible canting of the Arm. It also sports a Nylon Tipped Locking Allen screw
Nice that somebody readily makes spacers though, because originally I had to do such and have a donut spacer made, and had it black Anodized by a friend to match a older AQ PT-8 Arm (Jelco). Sold it then after the acquisition of the custom Arm Base.
jeff
Yamamoto headshells are a nice upgrade to a Jelco tonearm. Just bought a Jelco TS-550S MKII arm. Bought the Yamamoto Carbon Fiber headshell to go with it. Can't wait to mount my new Nagaoka MP-200 cartridge to the Jelco/Yamamoto!
I have the LP Gear Zupreme Headshell I bought a few years back and now I can use it on the Jelco 370H. It has for Azimuth adjustment.
The Yamamoto Carbon Fiber headshell has adjustable azimuth too! Most that I read, that have the Zupreme headshell like the Yamamoto Carbon Fiber headshell much better.
Yeah, I'm tempted to try the Yam. carbon headshell too. Be sure to post up your impressions.
jeff
Thank You for the info but I will be fine with the LP Gear Zupreme Headshell . That is better than the stock headshell that c with the Jelco 370H tonearm.
Cheers, it's a solid table, literally! I've always been in the 'mass is good' camp, especially when it comes to platters. WRT the other tonearm, it's a unipivot so very different to the Jelco, and it seems to work very well with the AT33PTGii, but I wouldn't say there's a massive difference in quality, to my ear the Jelco is a very competent performer, certainly with the carts I've tried on it so far.How does the Jelco 370H compare to the other tonearm on your table. By the way, very nice table!![]()
The zupreme headshell is a Jelco HS-25 sold under the LP Gear name. It's magnesium with adjustable azimuth as well so they are very nice headshells (their top of the line). They also come with high purity copper wire encased in silk. I have several. I could see a preference over the cheaper Jelco HS-50 which is LP Gears ultimate headshell. What is it about the Yamamoto CF that people prefer over zupreme? Other than slightly lighter weight (which could be positive or negative depending on compliance of your cartridge) I can't see anything significant.The Yamamoto Carbon Fiber headshell has adjustable azimuth too! Most that I read, that have the Zupreme headshell like the Yamamoto Carbon Fiber headshell much better.
