I had this odd-ball tube laying around.......tested it as a 12AX7, AT7, EU7, etc.....and tube didn't even light up......so I thought I toss it out. As it turns out......I just found it again....this time in the input position of a small push-pull EL-84 mono amp. Actually, I looked at the amp and saw it said 6EU7 on the chassis......so I just pulled the tube and stuck in another little amp I was working on.....and amazingly......it fired up and worked!! Considering this tube was 'supposed' to have been trashed, I don't really recall just how or when it got into the PP amp. I only use the PP amp as a platform for matching EL84 tubes while under a working load. I suspect I accidentally stuck this tube in the PP amp by mistake.....and this whole thing has resulted in my now finding that the tube actually works. My question is: What is it? I've looked it up on Duncan and NJ7P and can't find any record of the tube. It 'looks' just like any other 12AX7 type 9-pin. Any help w/ this would be appreciated.
Thanks,
Tom D.
Thanks,
Tom D.
