YES! I bought one when they first came out, and I still have it. It is a digital device, so not bucket brigade but rather shift registers. 3.5" tall with optional rack ears. They also made the Model 10 01 which did not include the 100WPC amp. There were many companies making similar devices at that time, I heard most, and the ADS was by far the best. The source ambiance extraction was, as best as I can recall, unique to ADS. So, it could do ambiance extraction or synthesis. Alas, hifitommy is correct, not all that reliable. The CMOS shift registers would fail easily. For a while, ADS sold TTL replacements, but those use considerably more power and replacing a few shift registers would then overload the regulator for the logic. After dicking around with it numerous times, I eventually unhooked the power to the delay boards and now just use it as a power amp. Sigh.
Even before it failed outright, I'd already removed it from my main system. While the spaciousness was extremely nice, the noise just got to me after a while. I then discovered a use for the Model 10 with subwoofers, which didn't have a noise issue, and I found new love for it again. That's when the shift register issues came up. The subwoofer trick was so amazing that I've contemplated DIYing a modern version that does essentially the same thing. I'll get right to it as soon as I knock off the other 20 things from my To Do list (perhaps).
