This article may answer some of your questions.
I can also email you the ADS consumer brochure that goes into some detail on how the processing is done, and the owner's manual (both too big to post here). You can send me your email via Conversations.
John
Well by the time I connected it up the 2nd time there was a problem! Argh! 1 channel is quiet depending on how the switches are set and how its encoded makes the output change volume greatly on one channel. Took a look inside and I instantly spotted a broken lead on a diode on the left side board that runs along the side in a verticle mount. Repaired it, then noticed the boards don't match left and right. One has obviously been replaced or repaired and capacitors are different manufactures and many are different values too. All the resistors are the same and diodes look the same but you know they are hard to see the actual numbers. In fact the one I replaced was nearly impossible to read the number, that's what made me look at the other board closely trying to find a match (I ended up using a very popular size and number with a 20 on it I have piles of them).
Fixing that diode made no difference! The amp section appears to still work fine when the jumpers are removed and the preamp is bypassed but it gets pretty warm after typical volume and normal use. It puts out about 1/10th of the power I'm used to running and it has found it's spot among a stack of other amps I'll never use, or several stacks of amps I'll never use.
I picked up a Behringer DCX2496 digital crossover (they call it a speaker management system) but it has the much needed DELAY available on all 6 outputs. This has allowed me to get my electrostats delayed to match the 2-8" low mids, while also allowing the 2x 8s to delay enough to match the single 12 on each side. The 8s are set at 12.xx milliseconds and the panels are delayed 4.xx miseconds more than the 8s so they're almost 17ms delayed from the 12s which are mounted on the side of each cabinet.
First day I had them finished and ready to test, initial run during mid afternoon last Saturday, just RTA'd them and found them to be running very close to flat (as flat as the mic can read, they claim 20-20KHz + or - 3db, I'm not that gullible, maybe 30 to 12KHz since that's where I see an immediate shelf drop of 6 db that never moves even though I can crank up the 16KHz setting and hear it getting way louder but never changes on RTA screen).
As I was saying, I didn't even have it cranked up loud at all, I was at about 8 o'clock on the dial and have my amps at 50% so I have some room to move the volume knob without being scared to touch it fearing it will be at concert levels if I bump it, and my nextdoor neighbor is pounding on my front door! I'm not sure how long he was there but between songs I could hear something. Actually thought I heard it at the break in last song but dismissed it. He's screaming at me to turn it down like I'm his kid or something! That's not the correct way to handle this, he saw me working on building the test cabinets all week long and had to know I was going to use them! So now I hate him and I'm sure his big deal is all about his dog freaking out from the subs I added and the new 550W RMS @4 ohms x2 amp powering them. Seriously, if he thinks that his yelling at me is the end of hearing my stereo, he's going to have some raw knuckles as far as I concerned he handled it way wrong being my neighbor, he knows I'm not going anywhere? He inherited his house after his mom died, she was very nice and the 60 something year old son that's been sponging off her since I bought my place 17 years ago has to have a roommate to be able to pay bills, and Homeowners fees, part time at Walmart, plus a 12pack a day habit probably barely covers it but at least his bicycle he rides is in good shape!
The time alignment has put the finishing touches on my system, I do have a 2nd set of DIY electrostats with 10" subs as well.
Test cabinets are heavily modified and ultra strengthened technics and Jensen towers. I'm starting on my own cab design now that it's cooled down in Phoenix. Going to start a thread for suggestions. I also have hundreds of other drivers I can use for subs and low mids.
