Poultrygeist
Lunatic Member
Thanks and it's fine to ask questions as that's the way I learned what little bit I know.
A fixed bias is one that has no adjustment and fixed bias/non-adjustable bias is pretty much the norm for single ended triode ( SET ) amps while the bias is adjustable and required for push pull amps.
You should consider the Sweet Peach FU50 single ended amp on ebay. It is rated at 10 watts and may have enough power to drive your B&W's at low to moderate levels.
The little Chinese flea amps are very affordable and the sound can be shockingly good.
