HalfApt
Well-Known Member
I'm not savvEE enough to analyze the individual parts of this circuit, but considering the functional blocks per the description, it's easier to understand how it works.I went into the preamp tonight. It took me awhile to remember how to disassemble it all. Anyway, all of the three capacitors are the correct value/voltage, 2x10uf 35v and 1x1uf 50v, and in the right orientation. I reflowed/cleaned all the solder joints in the section but nothing changed. What's interesting is then I measured the output voltage of the mute switch going to the relay that it starts at 25volts and slowly crawls down. once it's under a certain voltage flicking the mute switch works which may be somewhere between 17 and 18 volts. It continues to slowly go down but I didn't have it on long enough to figure out where it stabilized. What would be your next move if you were me? Replacing all all the transistors and diodes?
Update: I removed D14 and it tested fine out of the circuit.
When the time delay expires, transistor Q17 & Q18 turn on providing a ground path for the relay coil.
Initially, max current flows through Q19 providing a "surge" to ensure positive engagement of the relay armature.
When C67 (1uF) fully charges, Q19 shuts off, so now a lesser current flows through R90 (820 ohm), just enough to keep the relay engaged.
So a voltage drop is expected at the mute switch, but it should happen relatively quickly, not slowly as you say. If my math is correct, the "surge" should last just a fraction of a second.
Is a drop to 17-18V reasonable? Seems a bit much to me, but I don't know, depends on the relay coil resistance, which isn't specified.
OTOH, if you get 24-25V at the mute switch (terminal 5 on schematic) when first turned on, that should have engaged the relay already, so don't now what to think about that.
D14 is a flyback/freewheel diode to snub back EMF spikes when the mute switch is opened. If it's shorted or somewhat reverse conductive, it can/will prevent the relay coil from energizing properly.
Since it's parallel to the relay coil, measuring voltage across it in-circuit is just measuring the drop across the relay coil.
The circuit will work without it, so might be a good test, but back EMF will be introduced in the +24V line. Don't know how bad that might be. The 24v unregulated supplies are only used for the relay & headphone amp.
Hopefully a knowledgeable/experienced EE might join in.
