Yes about the AR 303, somewhere I read that Ken got some AR-3a samples to measure, one pair I think from
Tom Tyson. Maybe Tom wrote it up at CSP. Here's the Stereophile review:
It's a common audiophile failing to remember the past as being much better than it actually was. (Though, of course, some things were better.) I remember the first time I heard a pair of Acoustic Research LST loudspeakers, in 1974 or thereabouts. Compared with the Wharfedales I used in my own...
www.stereophile.com
Julian Hirsh review in Stereo Review pg 39 in the .pdf:
From Ken Kantor:
Tom Tyson posted this at CSP:
Although I had nothing whatsoever to do with the design of either speaker, I admire them both. I furnished a pair of mint-condition AR-3a's for Julian Hirsch to use in his June, 1995 *Stereo Review* audition of the AR-303. I did receive quite a bit of correspondence from Mr. Hirsch regarding testing both speakers, and for the benefit of the readers here, his comments from a fax on March 25, 1995, were as follows:
"The averaged room response of the two were remarkable similar, although the AR-303 had a markedly superior top end, above about 6,000 Hz. As a result, I set the two controls of the AR-3a to their maximum positions, which I believe was their usual preferred setting from the start if you wanted to sound as good as or better than your competition. The AR-3a was 2 dB more sensitive than the AR-303."
(Tom Tyson Note: putting both level controls at the maximum position will probably result in too much midrange. The usual preferred setting for best response has been to put the midrange slightly above the "dot," and the high-frequency control at or near maximum).
"On-axis MLS response measurements showed that the AR-303 was a clear winner on overall response and flatness. Its bass distortion was also lower than that of the AR-3a (and my old AR-1). In listening comparisons between the 303 and the 3a, the closest match occurred with the 3a controls set to the 'dots,' giving the two a very similar overall sound character. This was consistent with what I heard using a variety of program material. My conclusion was that the AR-303 has the best and deepest bass of any current speaker in its size range, and that a subwoofer is really not needed to improve it. I did couple it with my HSU subwoofers, and except for bringing out some 20-25 Hz. organ pedals a bit more prominently, it did nothing for the overall bass performance. Actually, this was the first speaker I have come across in recent years for which that could be said."
So it would seem that Ken Kantor and his staff (notably Bill Bush) succeeded in achieving their goals of keeping the family resemblence, yet improving an already-excellent design!
--Tom Tyson
