AR XA IN UK OK.....
joff
Sorry about the thread title :)
After seeing the AR XA s on here and elsewhere I realised that I needed one!
These appear to be quite rare here in Britain but I managed to find someone who had this:
I got the package delivered today and now I have to work out where it all goes!
One thing that does get me scratching my head is this:
Sorry about some of the poor images.
What the ... is it?
It is obviously for the motor but I have not seen this on any AR build or restoration threads before. Part of it looks like a potentiometer or something??
Being an AC motor all I could imagine it doing would be reducing voltage but not frequency.....
I have a long way to go but would really like to get some power on just to see it moving!
I forgot in your pictures doesn't show the bottom lid . In this lid should have the label of the turntable. In this label show of specifications of it and show the universal model.
yep, voltage selector switch, and its current position is set for 220-240
it will spin at wall frequency.......250rpm in your case. You have the correct pulley from what I can see.
Hi joff, your AR XA turntable is an universal model , I have the same turntable and that think is a selector voltage (120 volt-220 volt).
Now that makes sense! Thanks bichitus. Now I have to work out which wire goes where with the motor and this voltage selector. I have the Haydon? motor I think
This is what it looks like right now but there is no power connected yet
British Racing Green?
I plan to strip and repaint the top plate but would like to get it working first and refinish the cosmetics after I have listened to it for a while.
The arm will need some work and I am missing the ball for the tonearm well. :(
Marc, yes the motor has 4 wires all unhooked from this voltage selector. Any idea where they go?
I have on the motor white with green and white with red. then there is the black and yellow wires and the switch....?
It looks like you have a replacement arm tube installed because that is not the stock headshell. Make sure the fit into the arm pivot is secure and tight.
I think I see the arm cue mechanism that came with XAU units in the UK amongst the bits. If you can get that working it will be very helpful for operation.
Yes your right. This is an AR XA Universal as it states on the sticker. I cannot find out what order to wire the motor to the voltage selector though. :(
I have tried to get a photo from my deck. May be better if I get one in daylight
Hi joff, I will put photos of my voltage selector in my turntable, may be that it help you about the wires. Give time and congratulation, you have a very nice turntable.
Hi joff, here the pictures of my turntable (underneath). I hope this help you.
Regards.
P.D.: If you need another information or picture only let me know.20160917_200212.jpg 20160917_224810.jpg 20160917_224810.jpg 20160917_200343.jpg 20160917_200223.jpg
My deck has a serial number 273231 so is relatively young
Is it the other side of the board you need to see?
bichitus and cre009, those pictures are just what I needed. Thank you both for these.
Time to get the soldering iron out then.....
