lafaro
Hello,
I recently bought a AR XA in great shape from a guy that seems to take care of its vintage audio gear. Problem is, since I brought it home on a very bumpy car ride (roads in Montreal are often worse than a mine field...) it will only play in one channel. I read many topics on that particular problems but some details are bugging me.
First of all, I tried inverting the rca cables (putting left in right and vice versa) and it only changed the channel. I also plugged the TT in the aux input of my Marantz 2230 (bought from the same guy, in very good shape) and the problem was the same, just with very little output.
The first time I tried to remove the headshell from the arm it wouldn't go back tightly in place because the plastic threads of the headshell had disintegrated... I then bought a repro on ebay, installed it but the issue still prevail. Now that I can hear it properly, I can hear a light hum when the amp is at phono, whenever the TT is spinning or not. Could that hint bad rca cables?
Now, the one thing that bugs me is when I move the arm, I can hear some brief crackling. Once in place, I cant hear anything wrong. Should I be worried about that? Also, the platter is slightly angled, the left is a little lower than the right, should I do something about the suspension?
Anyway, sorry about the wall of text
I'm very eager to get the TT up and running as I've seen many praise about it sound (considering its a very old table).
Thanks!
Thanks!
