lafaro
Thanks for the tip, I've also took some picture of the original wiring with that red stripe to avoid messing these upremember on re installation, the red stripe goes up.
I've manage to desolder the original wires from the receptacle, there was not much solder in the first place but should I clean the pins like crazy? I can see the hollows and the new wires will go into the hollows easily, I'm just wondering if its bad to leave some bits of the old solder on the pins.
Also, I removed the black rubber and insulation from the tip of the new wire, should I remove it completely or is it better to leave some, on the part that will be inside the tonearm for instance.
. Now it is, I think, at an acceptable level but still a little bit lower on the left, does it make sense to unscrew a tiny bit the right headshell screw?
